• Building the Moon
    Mark Howe9 hours ago 0 comments
    All software is done. Starting to build up the lunar surface. Layer of spray glue, sprinkle with grout, repeat. So far so good, I think. Maybe a few more layers, then let the humidity in the air do the final curing.
  • Finishing Touches
    Mark Howe14 hours ago 0 comments
    Closeup of the back-lit Earth.
  • Control Box and Electronics
    Mark Howe3 days ago 0 comments
    Finally the electronics are done and installed into the control box with all the cables shortened and tucked away. Today put the final touches on the bulk of the programming. Added in modes to abort a landing at any point. Getting close. The finish is in sight.
  • Testing Moon Surfaces
    Mark Howe02/14/2021 at 16:54 0 comments
    One thing I've have to have to make this project stand out is a good lunar surface.  My current plan is to wet the landing surface with water, sprinkle on some grout, let it set for 30 minutes,  remove any excess, then repeat until it looks reasonable. I think this may work....
    A slight mod to the suface testing. Now spray the surface with adhesive, sprinkle on some grout, spray again, repeat. Also trying to insert a few random rocks into the mix. I think this is better and getting very close to the effect I'm looking for.
  • Electronics Work Begins
    Mark Howe02/14/2021 at 13:50 0 comments
    The PCB arrived from JCLPCB. Arduino Nano and sound card from Adafruit also now here. It's a simple circuit -- just a couple of motor controllers and some voltage convertors which could have been easily done with a perf-board, but I think having a real PCB makes everything look more professional.
  • Drag Chains and Limit Switches
    Mark Howe02/07/2021 at 17:56 0 comments
    Drag chains for cabling,  limit switches, adjustable limit switch contacts, and hard-stops in place.
  • First Test of the Stage Lighting
    Mark Howe02/05/2021 at 21:10 0 comments
    Finall got some of the neopixels wired up for a quick test of the stage lighting. Almost ready for final assembly.
  • Major Printing Done
    Mark Howe01/27/2021 at 22:27 0 comments
    Major printing is done. Gluing, filling, sanding, and painting next.
  • Printing continues and Sound Card arrived
    Mark Howe01/24/2021 at 16:41 0 comments
    Printing continues. Each verical section takes ~8 hours to print even at 5% fill setting. Nothing glued yet.
    The sound card arrived yesterday. Tested it today and loaded sound files from the Apollo 11 landing.
  • Printing the base and tower
    Mark Howe01/22/2021 at 19:21 0 comments
    After some thought, I've decided to print the base and tower. I figure I can always go back to the orginal plan of constructing it out of wood if it doesn't work out. It will just take some time. PLA with a fill density of 5% seems to be strong enough. With a little filler and sanding it should look good. Nothing is glued yet.
