All software is done. Starting to build up the lunar surface. Layer of spray glue, sprinkle with grout, repeat. So far so good, I think. Maybe a few more layers, then let the humidity in the air do the final curing.
A project log for Animatronic LEGO Lunar Lander
Goal is to simulate a lunar landng and take off with the LEGO Lunar Lander
