13D Print Case
2Install Pi KVM
Install the Pi KVM program on the RPi and configure
3Solder reset button to RPi
Solder wires from the reset pins on the RPi to the button
4Create custom USB cable
Wire schematic coming soon
5Install Components
Insert 18650 battery into UPS and slide into case. Plug USB cables into RPi and screw into place. Connect the ribbon cable from the RPi to the CSI-2 HDMI Input card and screw into place. Attach lid.
