Adafruit IO
A project log for Grow Light Feather Wing
A minimalist grow light that is compatible with the Adafruit Feather Huzzah dev board.
alexandra-covorAlexandra Covor 02/22/2021 at 22:000 Comments
Here's the code for adjusting the light intensity for each colour through the Adafruit.io app. I've also added a timer so that the light turns off after a number of hours (which can also be adjusted from the Adafruit IO dashboard).
