[H6X POD] Sensor Multi-Tool Platform
Your companion for the next Apocalypse.
Air Quality Sensors, UV, GPS, Heart Rate, Thermal Cam, 20Ah 60W Charger, 2x Torch
Public Chat
[H6X POD] Overview January '22
follow along on Instagram: https://www.instagram.com/zen.diy/
GitHub Code: https://github.com/lennypane89/H6X
Idea finding and background Story here.
Features
  • Robust and Smart
  • 2 High-Brightness LED Lamps Long-range + Dispersed
  • 2 Screens TFT + OLED
  • Trackball
  • Air Quality Index
  • UV Index
  • Thermal Camera
  • Heart-Rate Sensor and BloodOxygen
  • Weather Temp, Humidity, Pressure
  • GPS Location Compass, Steps, Altitude
  • SD Slot
  • 2-Port USB Charger 60W
  • Week - Month long Battery-life
  • Thermal Duct Cooling
DETAILSFunctionDetail                                                     Module
SENSORS
Air Quality
Thermal Camera
Heart Rate (and SP02)
UV-Index
Light Meter
Weather
Location
Motion
CO2VOC, NOx                                   SCD41, SGP41
8x8px - Interpolated 120x112px           AMG8833
                                                              MAX30102
UV-A + UV-B                                         VEML6075
LUX measurement                               VEML7700
Temp, Altitude, Humidity, Press           BMP390
GPS, Altitude, Compass                       PA1010D
Orientation, Compass, Steps               MPU9255
LIGHTLED ~2500lm Torch
LED ~1500lm Dispersed
5000K, +Button, 7/4 Modes                BLF A6
4000K, dimmable, high CRI, no Strobing
POWER
20.000mAh
60W Charging Out
30W Charging In
2S6P                                                     MJ1 18650
USB-C, USB-A, QC4+, PD3.0
USB-C, USB-micro-b
IO
TFT IPS 1.54"
OLED 0.91"
Blackberry Trackball
Main 240x240px                                 ST7789
Secondary Always-On 128x32px       SSD1306
4-Color status LED, Button
LOGGING
& DATA
SD Card Reader
HTML App
Logging, UI elements, up to 32GB
Data Monitoring, Settings, local Network
SYSTEM
ESP32
Thermal Duct System
Sleep & Power Save Mode
Electronic Path Protection
Redundant components
Sustainable
Robust Design
2 Core @240MHz, 4mb flash             DEV-KIT-C
/w two 20x20mm Fans
Extends battery life to weeks/months
Self checks, Auto-Shutdown & Warnings
Compass, Temp, AirQ, Screen, Power
Sources & Materials
Alu, Carbon, Boat Leather, Plexiglass
Use-cases
  • Outdoor and Adventure (traveling, off-the-grid/offline living, two-in-one high power Lamps, Air Quality Fumes and Gases low Oxygen alerts inside Boats/Cars/Tents/Caves, Compass and Location for trekking & tracking, UV Index / Sunscreen indicator)
  • IOT Station Logging and Monitoring for Weather and Air Quality Indoor/Outdoor (Air Quality Citizen Networks i.e. Canair.io)
  • Urban Air Monitoring Body Temperature and Air testing in Offices and Schools (general Air Quality and Virus prevention)
  • Emergency Intelligent hazard sensing & Alerts, GPS location, SOS lamp signal, health monitoring
  • Rural Areas with limited or no access to basic monitoring equipment, medical
  • Makers & Developers platform for sensor/module testing, modding
  • Smart Home Light HomeKit, smoke/gas warning, temperature, humidity etc
More Feature Ideas
  • Sensirion PM2.5 Particle Sensor (size constraint)
  • Carbon Monoxide Gas Sensor
  • Oxygen Sensor
  • Ozone Gas Sensor
  • Flammable Gases Sensor
  • Water Quality Sensor
  • GSM Network Connection / 4G
  • [H6X] UI Video Update
    eBender07/12/2021 at 12:19 0 comments
    Progress:  66,9%      Hardware: v9       Code: a10.0
    quick video of almost the whole OS.
    * Time and Heart Rate BPM is not working correctly right now.
  • [H6X] UI Update
    eBender05/24/2021 at 03:57 2 comments
    Progress:  66,9%      Hardware: v9       Code: v9.9
    I've been working on the UI and made some progress i want to share.
    Mainly Home and Menu Screens and some minor updates.
    I realised i haven't featured the Air Quality/indirect virus detection theory
    functionality yet, that will be getting its own post soonish.
    These are actual screenshots of the display (or photos rather, haven't figured out the eSPI screenshot readRect() code yet). Some pages are still cluttered and older, and i have yet to implement smooth fonts, but it's at a good state to show and explain.
  • [H6X] State of the build #4
    eBender04/28/2021 at 23:27 0 comments
    Progress:  65,6%      Hardware: v9       Code: v9.8
    Change-log
    • implemented AMG8833 8x8px Thermal Cam
    • added Button2 library for Interrupt double-click detection
    • enabled INA260 Interrupt low voltage alarm to trigger system power off through Buck converter EN pin
    • removed pull-up resistors on all I2C sensors, keeping 10k main I2C pull-ups
    • bug fixes
    Issues:
    • detecting SD unmount or error inside Loop() not working anymore
    • removed MPU9250 for AMG8833 to work (I2C addresses)
    AMG8833 Functions:
    Using Algorithm from the Adafruit AMG88xx Library.
    Screen shows:    Center Point Value, Max Value, Min Value, fps,  Interpolation Time
    • LowRes Mode      30x28 Pixels Interpolated, 12 fps
    • HighRes Mode     120x111 pixels Interpolated, 1 fps (+Auto-Exposure)
    • Full Screen burst mode    collects the highest value out of the full array
    • Center Point burst mode  collects the highest value out of the 2 center pixels
    Button Single-Click:    Trigger Burst Measurement (small 0.49" screen shows 3-sec countdown)
    Button Double-Click:  Toggle Measurement Area (Center Point, Full Screen)
    In HighRes mode i maxed out the Resolution so the frame Rate drops to 1. The Colour Temperatures are mapped to onscreen Min and Max Temps. Kinda works like a simple exposure compensation in a normal camera. The adjusted values get passed on to the LowRes mode if switched. Default temperature scale is 22C - 33C.
    It features a Burst Mode (Averaging Mode) to get a more accurate reading with the 8 bit sensor values, by averaging 50 samples over 3 seconds. Measurement will always be taken from the highest temperature seen by the Sensors inside the selected Measurement Area (Full Screen (64px) or Center Point (2px)).
    Issue: i can't, for the life of me, figure out how to access the full color spectrum to have smooth color transitions. I tried using the eSPI colors and a conversion method, but could only get it to work by accident with smooth colors going from dark blue to purple, and dropping 6 fps. no good. Could have something to do with the 16bit color mapping and how they are arranged in the array, since the actual 8x8 sensor values are 8-Bit, but the array only holds about 32 or 64 colors it looks like. i don't understand how to map the array correctly, or where to get a premade one.
    more after the jump:
  • [H6X] State of the build #3
    eBender04/23/2021 at 17:18 0 comments
    Progress:  64,8%      Hardware: v9       Code: v9.8
    Update: Time for some pictures of Hardware implementation and UI progress:
    Prototype v9
    Layout of Battery pack, power & charging boards inside the Thermal Duct, that the empty battery slot creates.
    Components are mounted on Aluminium heatsink that goes from top to bottom with maximum exposed surfaces to the Airflow.
    There are two levels of PCBs in this design. 3x 2S 2A Chargers(?), 4x 3A voltage buck converters, INA219 + INA260, 400w PWM Controller, 2S 20A Protection/Balance Board. Hoping Air will still flow ok.
    Also still figuring out the power path for charging.
    Loading Screen
    Loading Screen (random selection of 12 different screens), shows loading errors and reset reason
    Progress with the UI:
    It's still not very beautiful, but already does almost everything that was planned.
    Battery Pack tinkering & Electronics Prototype
    Home Screen displays most important Data Points
    Home Screen displays most important Sensor Data.
    The whole System has a warning Screen for critical Over/Under - Temperature, Voltage, Current, Wetness values and sets everything into Low Power / deepSleep modes.
    Phone-like Status Bar for SD card, Logging, Fan, WiFi, Battery, FPS, Lamp, time since reboot.
    Small 0.49" Screen cycles through sensor values, shows alarms and indicates charging.
  • [H6X] State of the build #2
    eBender04/23/2021 at 12:21 0 comments
    Progress:  61,4%      Hardware: v9       Code: v9.7
    Change-log:
    • replaced MLX90614 BCC with AMG8833 64px Thermal cam
    • added Sensirion SCD30 - CO2, Temperature, Humidity Sensor to support fairly inaccurate CCS811 & HDC1080
    • added secondary tiny 0.49" OLED screen (displays sensor & error data)
    • added additional INA260 Voltage & Current Sensor (15 Amps max)
    • added mini GPS Module in plans (not ordered yet, still researching - PA1010D ?)
    • added self-error checking/disabling for Sensors & SD reader
    • sped up code by a lot! (avg 80 fps)
    • made progress with UI/UX menu (new Debug & Info Screens, Charge Indication etc...)
    • implemented deep Sleep & low Power Modes
    Issues:
    • conflicting I2C adresses for RTC, MPU & AMG8833 (go Serial? or one has to go)
    • how to manufacture precise aluminium bends (r 1.75cm)
    • voltage still unstable bc of  janky breadboard/cables & too many components (occasional i2c errors) guessing  soldered connections and better wires will fix this
    Issues with the power Path/Charging:
    USB-C input needs 9v from wall charger to work, because i am using non-balanced 2S, 8.4v, 2A charging modules that don't boost the voltage.
    i tested multiple 2S charging boards TP5100 in parallel and i think it killed 2 of them. So charging would be limited to 1 charger with 2A max, which would take way too long (over 16h). Maybe going 2S was a bad idea, but it gives me the ability to toggle these (HW-313, 3A) voltage buck converters on and off via their enable pins. And voltage conversion differences between battery voltage and the component voltages are lower. (highest is 12v, lowest 3.3v)
    Having a balanced, protected 2S (3 terminal) buck-boost converter/charger supporting 7A with USB-C PD4.0 polling for voltage, input and output switch, would be a dream (MJ1 Batteries support 6.8A charge rate, which would take 6h30).. if my math is correct.
    I know designing a custom PCS with charging/power/protection/management features, sensors and as much as fits on it would probably be the best solution, but i don't have the expertise yet. Arduino and Alibaba modules it is for now.
    unless someone wants to help?
    New Component / Feature Illustration:
  • [H6X] State of the build #1
    eBender01/25/2021 at 22:26 0 comments
    Progress:  42,7%    Hardware: v7       Code: v7.3
    Issues:
    • Airflow, heat management, heat expansion of materials.
    • Getting my prototyping circuit up and running again. switched to a new breadboard and wires and now all the voltages have dropped.
    no idea how to tackle the charging path. Schematic &  more Details after the Jump
  • First Concept Renders.
    eBender01/25/2021 at 22:08 0 comments
    This was my first version. With a hilariously complicated tray, pushed by a tiny linear Actuator, comes out to show you all its brains. Moved away from that. Also the old version was much bigger and heavier with a double 9x9 18650 Pack.
    Going for a 6x6 Hexagonal design now.
  • Sensor Testing.
    eBender01/25/2021 at 22:05 0 comments
    Had first successes with the CJMCU-8128 (CO2, tVOC) and MAX30102 (HeartRate), WiFi, Screen:
  • Proof of Concept.
    eBender01/25/2021 at 21:59 0 comments
    This is the first prototype, to give Aluminium bending and tolerances a try. Also ordered 3 different materials for the cover. Denim, and two types of faux Leather.
  • How the Idea found me.
    eBender01/25/2021 at 21:44 0 comments
    i had the Idea after i returned from India where i had been traveling on Foot, Train and Motorbike from North to South and back.
    Around March 2020 I was spending my time with new friends in Rishikesh, one of whom slowly got really sick, right when COVID really started in India. We questioned bringing her to the Hospital but couldnt really tell, no doctors to find and the medicine shops gave us wrong or fake antibiotics, which didn't help. So, during that time we had the need for a thermometer but couldn't find any after searching whole Tapovan. Her condition worstened and nothing helped, so after a lot of convincing and back and forth, we brought her to the Rishikesh Hospital, masked up and evading the doctors in the entrances, who were to trying to catch and test all the "Covid Tourists". We found out, after the usual India chaos, that she had a bladder infection that had started spreading to her kidneys.
    She stayed in the hospital for 4 days, we visited.
    That gave me this idea, what if I could build a thing that had say, Body Temperature and HeartRate monitor, a Powerbank and a Lamp. We definitely wouldn't have been so clueless and unaware of the danger that she had been in. Our friend slowly got better with the help of antibiotics. Right after that, we decided to leave from Delhi for Germany with the last Government chartered ariplane, wich we almost missed.
    Back in Germany i started planning. Very little know how about machining coding etc. but i'm getting there, slowly but surely.
    Going through all the available arduino sensors and now looking into industrial sensors.
    Getting into deep rabbitholes about for example thermal conductivity of aluminium vs copper variants.
    Trying to add functionality into every last square mm while keeping it 'minimal' and robust.
View all 10 project logs
isabellaanna255 wrote 08/07/2021 at 04:47 point
I will suggest you to carry on your hard work on it  I am also working on a falconapk website project you can see here.
Daniel He wrote 07/25/2021 at 04:03 point
Cool project!
Since it is an apocalypse companion, I would also suggest a geiger counter feature for potential nuclear winters.
eBender wrote 07/26/2021 at 10:33 point
oh yea definitely! already looked into that, the good ones i found are pretty big and don't fit for now, unless i remove batteries.
there is a full list of more feature ideas at the bottom of this post:
https://hackaday.io/project/180257-h6x-pod-2021-hackaday-prize-entry/details
edit: now also in the details of this project page.
polidax198 wrote 06/09/2021 at 13:30 point
This project is looking very unique I will suggest you to carry on your hard work on it  I am also working on a smokersgeek website project you can see here.
Esteban wrote 04/26/2021 at 13:38 point
Genius design and great idea!
eBender wrote 04/26/2021 at 13:58 point
thanks man!
setCREATE wrote 04/25/2021 at 20:31 point
Really cool Idea! For the controller chip, have you thought of using an MC60 module? it has the SD Card, GPS, GSM, and many other features already on itself, it can save you a lot of space.
also, does this thing have a sleep mode? for like expanding the battery life to some crazy amount of time?
eBender wrote 04/25/2021 at 21:09 point
hey thanks, good suggestion! i have not seen that particular model yet, but i have considered similar modules. It is almost the perfect solution for this (plus would add GSM), but i think after the arduino phase i'm going to go one step better and design a custom pcb in the perfect hex shape with those components and better power management, i'm still pretty limited by my expertise, though.
But next up is finishing the prototype as i have it, to test functionality, usability and feasibility.
sleep and power-saving modes are already implemented for the esp32 and most of the sensors (the ones that have an easy sleep/power-off mode in the code). Toggling deepSleep via html app and then working off of the RTC and ULP timer with configurable wakeup/sleep times. I (very loosely) estimate the battery life to be over 4 weeks on low-power/deepSleep mode with interval logging, probably longer (if its not used for device charging or lights)
setCREATE wrote 04/26/2021 at 06:00 point
That's great, keep it going.
