0.91 Inch OLED Monitor
You don’t have to manually label the Pis any more, there’s a tiny screen displaying the temperature, ip address, CPU and memory usage, it can also be customized to show any information you want.
This isn’t something you can find in a regular or 3D printed rack mount.
All ports at the Front Panel
If you change Micro SD cards a lot, and have suffered from not being able to see the blinking power LED, you will know how important repositioning the slots is. When you ran into hardware issues, these small improvements can save quite some trouble.
Dual HDMI Output
We've brought out two regular size HDMI ports with a customized type-D-to-type-A connector adapter board, this way you can use normal HDMI cables with any of the Pis, and as usual, they’re bundled with the rackmount.
Power switches
To make things better each Pi also gets a latching-style push button switch, you only need to plug the cables once, this will come in handy whenever you need to cut off the power or reboot one of the boards, it makes power management a breeze.
I'm curious a) where you are sourcing your Micro HDMI components and b) what your mechanism for attaching them to the PCB is. I've not designed a project with this component yet but am trying to figure this out.
