Impending simplification
A project log for A Cheap Compact Linear Slide
<$10. <10μm repeatable. >10kg capacity. Laser-cut 1/8" hardboard. For 100mm x 6mm rod, but semi-parametric. Handwheel or stepper drive. CAD.
paul-mcclayPaul McClay 03/19/2021 at 02:040 Comments
While writing up "details" for this project and its "silly long" instructions doc, I added:
...I've just thought of an easier-to-describe assembly sequence that might work. It might cost some flexibility for post-assembly tinkering, but maybe that's a good trade for nearly everyone.
And then I went and tried that. Fail. But failing lead to another idea that worked. So hopefully the "Assembly" doc will get thinner "soon".
(removed that bit from the "details")
