STL Files released 16/01/2021
A project log for Edog - Mini 3D printed Quadruped Robot ✨
Hi, I'm edog, a 3D-printable quadruped robot
gaultier-lecaillonGaultier Lecaillon 07/16/2021 at 20:250 Comments
I finally uploaded stl parts online for Edog !
Prints are extremely simple, you don't need any support if you set the "support overhang angles" to 51°. The only trick is to print two "tibia" mirrored in order to print left and right tibia, the femur is already symmetrical and can be printed 4 times.
Download link: https://www.thingiverse.com/thing:4910279
PS: I didn't publish the shell, I'm not satified by the shape, I will uplaod it later :)
