N**** Style Home Info System
A Home Info System (a.k.a Clock) Which displays the Time, Date, Humidity, Temperature, Barometric pressure and Moon Phase
A Home Info System (a.k.a Clock) Which displays the Time, Date, Humidity, Temperature, Barometric pressure and Moon Phase. I finally got rid of the dvd player that was only used for the time it displayed (the player itself stopped working years ago). But that left a large empty space especially noticeable when ever I looked over for time based answers. So I recently bought a Gixie clock that broke after a few hours so I decided to build a decent one myself.
Portable Network Graphics (PNG) - 503.49 kB - 03/03/2021 at 20:04
Preview
plates.svg
All the used plates (first plate is also used as plate 7 & 8
svg+xml - 29.35 kB - 02/01/2021 at 19:41
Preview
  • 18 × 8 WS2812 LED Strip https://s.click.aliexpress.com/e/_A7hgur
  • 1 × BME280 i2c (Barometer with temp and humidity) https://s.click.aliexpress.com/e/_9RUGYn
  • 1 × High Precision Real Time Clock i2c https://s.click.aliexpress.com/e/_ATYF5z
  • 1 × Arduino Nano Clone https://s.click.aliexpress.com/e/_A29Wwj
  • 1 × Arduino Nano Expansion Board https://s.click.aliexpress.com/e/_AZOA1Z
View all 6 components
  • Display test
    SephenDeVos03/03/2021 at 19:53 0 comments
  • Panels & Assembly
    SephenDeVos03/03/2021 at 19:37 0 comments
    Rear view
    Top
    Front
    Front right
    Bottom
    Cut-out for the BME280
    Laser cut panels with a PU varnish
  • Electronics
    SephenDeVos02/05/2021 at 11:34 0 comments
    Build a board to store all the components. The bme280 will be in its own compartment away from any heat from the electronics.
    Having acces to a laser cutter takes your ideas to the next level.
  • The character display units
    SephenDeVos02/05/2021 at 11:15 0 comments
    I use these little ws2812 boards they're about 10mm x 50mm, you can find the here.
    Soldered all the LED string and put double sided tape on them.
    One string done.
    Looped the LED string around the support plate.
    Stacked all the plates "et-Voila!" all the units are done. Some of them still have the protective film on them.
  • LED Breakout
    SephenDeVos02/01/2021 at 19:34 0 comments
    Every unit uses 3 ws2812 breakout boards with 8 LED's
    Soldered in series to create a row of 24 led's (3x8 grid)
  • Element Plates
    SephenDeVos02/01/2021 at 19:27 0 comments
    One unit is build up from 8 stacked 45mm by 83.5mm laser-cut plates.
    1 - 6 are 3.5mm plywood. 7 white acrylic 3mm. 8 smoke/grey acrylic 3mm.
    1) Back. 2) Space for the wires. 3) Mounting plate for the Led breakout boards. 4) Alignment plate for the Led breakout boards. 5&6) light guides to direct the light. 7) diffusion/projection plate. 8) dimming plate.
View all 6 project logs
