Display test
03/03/2021 at 19:53 • 0 comments -
Panels & Assembly
03/03/2021 at 19:37 • 0 commentsRear view
Top
Front
Front right
Bottom
Cut-out for the BME280
Laser cut panels with a PU varnish
Electronics
02/05/2021 at 11:34 • 0 commentsBuild a board to store all the components. The bme280 will be in its own compartment away from any heat from the electronics.
Having acces to a laser cutter takes your ideas to the next level.
The character display units
02/05/2021 at 11:15 • 0 commentsI use these little ws2812 boards they're about 10mm x 50mm, you can find the here.
Soldered all the LED string and put double sided tape on them.
One string done.
Looped the LED string around the support plate.
Stacked all the plates "et-Voila!" all the units are done. Some of them still have the protective film on them.
LED Breakout
02/01/2021 at 19:34 • 0 commentsEvery unit uses 3 ws2812 breakout boards with 8 LED's
Soldered in series to create a row of 24 led's (3x8 grid)
Element Plates
02/01/2021 at 19:27 • 0 commentsOne unit is build up from 8 stacked 45mm by 83.5mm laser-cut plates.
1 - 6 are 3.5mm plywood. 7 white acrylic 3mm. 8 smoke/grey acrylic 3mm.
1) Back. 2) Space for the wires. 3) Mounting plate for the Led breakout boards. 4) Alignment plate for the Led breakout boards. 5&6) light guides to direct the light. 7) diffusion/projection plate. 8) dimming plate.
