Reverse voltage protection
A project log for SuperCAP BKUP
A Supercap power backup solution for small devices. Small being relative, depending on the size of the cap ;)
magicwolfiMagicWolfi 02/08/2021 at 20:230 Comments
Note to self:
1) Linear regulators must be protected against reverse voltage through a Schottky diode in the antiparallel configuration (output to input) or a diode before the regulator (bad).
2) Do switching regulators need protection too?
