Colors! (sn65dsi83 test pattern)
A project log for Put a Raspberry Pi CM4 into an original iPad
Open up a 2010 iPad, remove its logic board, and fabricate a new board based around the Raspberry Pi CM4.
evanEvan 08/23/2021 at 06:260 Comments
Thanks to the help of some folks on the Raspberry Pi forums, I've got the sn65dsi83 driver loading, and the Pi generating enough DSI signal for the SN65DSI83 to be able to generate a test pattern (it uses the DSI clock to generate the LVDS clock)
Hopefully I can get those black lines to go away.
