OBS_IRL_STREAM_DECK
CONTROL YOUR OBS WITH A WEARABLE
A WEARABLE OBS CONTROLLER (STREAM DECK) UTILIZING MQTT AND NODE-RED
ALL CODE AND CAD IN GITHUB REPO'S
Tech demo glove controlling live stream effects during the IRL stream
https://clips.twitch.tv/CheerfulInventivePidgeonPraiseIt-iaRoMfRgHXwslbsG
some more demo!
https://clips.twitch.tv/PluckyPiliableBasenjiImGlitch-BFIjQvBhsSrbF_Tk
  • 1 × SPARKFUN ESP32 THING PLUS ESP32
  • 15 × GATERON ks-9 BUTTONS
  • 1 × Diymore Double 18650 V8 Lithium Battery Shield Micro USB 5V/3A 3V/1A Power Bank POWER REG
  • 2 × 18650 V8 Lithium Battery BATTERY
  • 1 × PC WITH DOCKER PERSONAL COMPUTER
View all 6 components
  • 1
    DOWNLOAD_CAD
    FOUND IN THE GITHUB LINK IS A LINK TO BOTH THE FUSION360 FILE AND A STEP FILE VERSION OF THIS GLOVE/BRACER.
    USING FUSION360 YOU CAN MODIFY THE ARM MODEL TO MATCH YOUR OWN. THIS WILL ALLOW THE GLOVE TO FIT YOU PROPERLY.
  • 2
    Docker
    This is not going to be an in-depth docker tutorial, but just the bare minimum. Search for Docker, install for your system.
    Then docker pull the following images: https://hub.docker.com/_/eclipse-mosquitto and https://hub.docker.com/r/nodered/node-red
    follow those pages to run the containers.
    Alternatively, you can install node-red on your system natively, since it may give you a little more flexibility with other software. You can also install eclipse mqtt on a raspberry pi, which is also popular to do.
  • 3
    OBS Websockets
    If you have not already, install OBS from their website.
    Then download and install obs websockets. It is a fantastic plugin! It allows other scripts, programs, and containers to communicate and control obs via websockets!
View all 7 instructions
JVS wrote 2 days ago point
Wow, trippy
nate.damen wrote 2 days ago point
Thanks, JVS!
Richard Hogben wrote 4 days ago point
This is some TheSushiDragon quality content :)
nate.damen wrote 4 days ago point
I cannot read quality content without hearing and seeing his effect in my head, 🤣. He is amazing!
