CoilWinder based on grbl for ESP32
This quick project implements a coil winding machine with an ESP32 SoC and two stepper motors.
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The coil winder software is based on the Grbl Grbl_ESP32 firmware and coilwinder.py script to create .gcode files.Changes from the original Grbl firmware:- coilwinder.h machine configuration with settings for two stepper motors.- report.cpp changed to support a (somewhat clunky) driver for an SSD1306 OLED display. The display is used to show the current CNC statusThe coilgen folder contains a Python script to generate .gcode from a coil's parameters. The gcode file includes a comment with the coil's turn and layer counts, which is displayed on the OLED display.
