Hackaday.io Hackaday.io
Sign up Log in
Digital Wi-Fi Candoliers
ESP-01 Widow Candle
shepler007shepler007
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
0 followers
  • Description
  • Details
  • Files 4
    • View all
  • Components 4
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
157
0
0
0
Team (1)
  • shepler007shepler007
Join this project's team
MISC
ongoing project
holiday christmas candle
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 02/03/2021 and last updated 2 年前.
Description
In New England, it is a long-held tradition to set a candle in every window to welcome weary travelers (and family and friends during the holidays). I have designed these to work using ESP8266 (ESP-01 modules) and three WS2811 RGB LED pixels with a custom printed circuit board (PCB) that can be made with breadboard using a schematic. The ESP-01 module runs forkineye firmware (forkineye.com) and I control them with Node-RED running on my Home Assistant server. Each low-voltage candle lends a warm glow to your home, especially during the holidays. This design offers single candles and three-tier candoliers. The candoliers look especially festive when placed in a window, on table tops, or on a fireplace mantle, adding the joyous glow of this time-honored candolier. Features: - Inspired by original colonial window candles - Designed for indoor use - Can be used year-around - Single window candle - Triple window candle
Details
Files
3 Candle Stick 2.0 - Holder.stl
Standard Tesselated Geometry - 7.45 MB - 02/03/2021 at 17:51
Download
1 Candle Stick 2.0 - Holder.stl
Standard Tesselated Geometry - 3.46 MB - 02/03/2021 at 17:51
Download
Candle Stick 2.0 - Flame.stl
Standard Tesselated Geometry - 1.53 MB - 02/03/2021 at 17:51
Download
Candle Stick 2.0 - Candle Stick.stl
Standard Tesselated Geometry - 2.53 MB - 02/03/2021 at 17:51
Download
Components
  • 1 × Esp-01 ESP8266 Wi-Fi Module
  • 3 × WS2811 LED Pixel 12mm 5V DC IC LED Module
  • 1 × 5v Regulator
  • 1 × 4 Color 10m RGB Extension Cable
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Control the intensity of the dimmable lighting appliances via a trailing edge dimmer.
Project Owner Contributor
Multichannel Wireless Light Dimmer
abhishekkonaleabhishek.konale
Supplyframe DesignLab: 2023 Hackada…
This is a simple and cheap DIY MODBUS-gateway with WiFi
DIY MODBUS TCP/RTU Gateway with WiFi
ruslanRuslan
Information is available every where, and can be used in so many ways.
Munich subway tracker
vinciusVinícius
Knight Rider scanner lights for your server rack - analogue style!
RacKITT - Rack mount scanner bar using op-amps
eontronicsEontronics
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Digital Wi-Fi Candoliers", please tell us the reason.
Send message
Remove Member
