Frame: Creality Ender 5 Aluminum profile based, CoreXY Kinematics: Voron 2.4, Self Leveling Print Bed: HevORT, High Temperature
Not a member? You should Sign Up.
Already have an account? Log In.
Standard Tesselated Geometry - 86.41 kB - 02/26/2021 at 22:36
Standard Tesselated Geometry - 1.44 MB - 02/24/2021 at 15:51
Standard Tesselated Geometry - 1.17 MB - 02/24/2021 at 15:51
Standard Tesselated Geometry - 331.43 kB - 02/22/2021 at 04:14
Standard Tesselated Geometry - 273.52 kB - 02/22/2021 at 04:14
View all 11 files
View all 10 components
Components: https://hackaday.io/project/177303/components
3D printed files STL: https://hackaday.io/project/177303/files
VorEnder 5 - X and Y linear rails
Frame size (outside) : x:410mm, y:410mm, z:440mm.
All aluminum extrusion 2020 and 2040 went from old Ender 5 3D Printer frame and have their original length.
I have added eight M3.5holes (four on two top and four on two bottom profiles) as an access for M5x10 blind joints button head cap screw.
Vorender 5 - Frame Concept
View all 5 project logs
jofersontayag
Shulie Tornel
Terje Io
TomKeddie
Yes, delete it Cancel
You are about to report the project "Vorender 5 - HT Core XY 3D Printer", please tell us the reason.
