#7- VorEnder 5 Core XY 3D Printer - CoreXY Belt Tensioners. Left and Right Front Idlers
A project log for VorEnder 5 Core XY 3D Printer
Voron 2.4 inspired build using Ender 5 3D Printer frame profiles as a base and some parts laying around :)
dareknorwayDarekNorway 03/30/2021 at 15:200 Comments
Two F695 2RS Bearings Stack Idler
Two F695 2RS Bearings and Two M5x1mm Spacers Stack Idler
RainDew F695-2RS Bearing 5*13*4 mm ABEC-7 Flanged Miniature F695 RS Ball Bearing
https://hackaday.io/project/177303/components
