#24- VorEnder 5 3D Printer - Buildplate - Heat Bed
A project log for VorEnder 5 Core XY 3D Printer
Voron 2.4 inspired build using Ender 5 3D Printer frame profiles as a base and some parts laying around :)
dareknorwayDarekNorway 03/12/2023 at 10:280 Comments
VorEnder 5 Buildplate/Heatbed sandwich:
1 Double sided Textured PEI Spring Steel 257x257mm
2 Magnetic rubber plate Energetic 260x260mm
3 Custom made 255x255x6mm glass base
4 260x300mm 468MP Double Sided Adhesive Transfer Tape
5 Creality 235x235x3mm Creality Ender 5 Aluminium Baseplate Heater P=220W 24 VDC
6 Transparent Silicone Rubber Sheet 260x260mm 1mm
