#25- VorEnder 5 3D Printer - Video - Print test Velocity 300mm/s Acceleration 10000mm/s2
03/26/2023 at 17:36 • 0 comments![]()
#24- VorEnder 5 3D Printer - Buildplate - Heat Bed
03/12/2023 at 10:28 • 0 commentsVorEnder 5 Buildplate/Heatbed sandwich:
1 Double sided Textured PEI Spring Steel 257x257mm
2 Magnetic rubber plate Energetic 260x260mm
3 Custom made 255x255x6mm glass base
4 260x300mm 468MP Double Sided Adhesive Transfer Tape
5 Creality 235x235x3mm Creality Ender 5 Aluminium Baseplate Heater P=220W 24 VDC
6 Transparent Silicone Rubber Sheet 260x260mm 1mm
#23 - VorEnder 5 3D Printer - Z axis - Bed Frame
01/21/2023 at 11:44 • 0 comments -
#22 - VorEnder 5 3D Printer - Z axis - Carriages and Lead Screws
01/15/2023 at 19:30 • 0 comments- Front left and right Lead screw (2x): 330mm 304 Stainless Steel Threaded Rod Lead Screw with T8 Brass Nut for 3D Printer, Pitch: 2mm
- Rear Lead screw: (1x) Stock Ender 5 T8, 2mm Pitch Lead screw (Original 370mm, cut to length ¨345mm)
- Stepper Motor Couplings 5x8mm (3x): Kande BW Three Jaws D25L30 Coupler Aluminium Plum Flexible Shaft Coupling Motor Connector CNC Flexible Couplings
- Aluminium Spacer Z-axis Carriages (3x): 8mm x 5mm x L=8mm (From Ender 5 X-axis carriage)
- 3D Printed Carriages Parts: Files | VorEnder 5 Core XY 3D Printer | Hackaday.io
- Components | VorEnder 5 Core XY 3D Printer | Hackaday.io
#21 - VorEnder 5 3D Printer - Z axis MGN9 Linear Rails
12/31/2022 at 12:46 • 0 commentsTree z-axis 9mm Linear Rails : MGN9 L=350 KGT Linear Rail with MGN9-H block
Alignment MGN9 Linear Rail with 20x20 Aluminium Extructions V type Profile
Alignment MGN9 Linear Rail with 20x20 Aluminium Extructions V type Profile -
#20 - VorEnder 5 3D Printer - Grease Z axis Linear Rails
12/29/2022 at 17:07 • 0 comments -
#19 - VorEnder 5 - 5015 Blower Fan mod for Voron Afterburner
12/19/2021 at 11:22 • 0 commentsBlower Fan: Dual Ball Bearings GDSTIME 5015
Mod Repository: https://github.com/Greg191134/Voron/tree/master/Afterburner%20Optimisation/5015%20fan%20mod
VorEnder 5 3D Printer components list: https://hackaday.io/project/177303/components
#18 - Z-axis Rear 2020 Aluminium Extrusion - VorEnder 5 3D Printer
12/18/2021 at 13:38 • 0 comments -
#17 - Voron Afterburner Microswiss Tool Cardridge - VorEnder 5 3D Printer
12/12/2021 at 14:47 • 0 commentsSTL files: VORON printhead for MicroSwiss hotend https://www.thingiverse.com/thing:4705446
Hotend: Trianglelab Swiss CR10
#16 - VorEnder 5 3D Printer - Electronic Compartment (Part #1)
12/10/2021 at 12:25 • 0 commentsCreality Ender 5 Electronic controller box with FYSETC Spider V2.2 Motherboard 32Bit RRF Controller Board
Fysetc Spider brackets for Ender5 Controller Box - STL Files to print: https://hackaday.io/project/177303/files
PSU and IEC inlet module AC power socket: https://hackaday.io/project/177303/components
DarekNorway
