Upgraded lens for Raspberry PI V2 camera
3D printed a holder so that I can use my old SLR lens with the raspberry PI v2 camera
Public Chat
I had some older lenses for a Pentax SLR camera. They have manual aperture and focus adjustment so they lend themselves to working for this project.
I had some older lenses for my Pentax SLR camera.  The lenses have manual focus and manual aperture control.  So, I went about designing a 3D printed holder for the lenses and the raspberry pi camera module V2.
First, I measured the Pentax SLR camera body - particularly the distance from the lens mount plane to where the film was.  Then, I designed a barrel and holder so that the bayonet lens can twist into the print, the raspberry pi camera module v2 can mount on the other side, and the whole thing can be mounted securely.
Note - you have to take off the original lens that shipped with the raspberry pi camera module v2.  You can use the lens removal tool that came with the camera, or 3D print your own (  https://www.thingiverse.com/thing:1574661  ).
It worked out pretty well!  Here is a photo using a 28 mm lens.
The distances were roughly correct - the subject was about 2 m away, but the lens reading was about 1m.
I put some black construction paper on the inside of the print to help block the light, but there is still a little light leaking through the back, so the picture has a delightful blueish tinge.  :)
Since the lens ended up a bit closer to the sensor, then you can always add spacers at the back where the sensor is to adjust the lens through normal to macro operation.  You only need a few millimetres, which is something I never fully appreciated until this project.
Note that the sensor area is quite a bit smaller than the film for the SLR camera, so you get a smaller slice of the image.
Pentax_Raspberry_PI_v2_mount.stl
STL file of the mount
Standard Tesselated Geometry - 345.09 kB - 02/05/2021 at 16:15
Download
roundedendpost.scad
Helper file for the mount
scad - 666.00 bytes - 02/05/2021 at 16:15
Download
Pentax_Raspberry_PI_v2_mount_ScienceDude.scad
OpenSCAD design of the lens and pi camera mount
scad - 4.59 kB - 02/05/2021 at 16:15
Download
  • 1 × Raspberry PI 3 Model B+
  • 1 × Raspberry PI Camera Module 2
  • 1 × Manual SLR lens
  • 1
    Ramdisk for raspberry pi
    So, you want to take a bunch of photos, but don't want to burn the SD card on the raspberry pi?  Place the files on a ramdisk.
    Make the ramdisk
    sudo mkdir /mnt/ramdisk
    Edit the rc.local file
    sudo nano /etc/rc.local
    Add the lines above exit 0
    mount -o size=30M -t tmpfs none /mnt/ramdisk
    /bin/chown pi:root /mnt/ramdisk
    /bin/chmod 777 /mnt/ramdisk
    Reboot, then check the file structure with
    df -h
    Now, when you use raspistill, direct the output to the ramdisk
    i.e.,
    raspistill -n -t 2 -o /mnt/ramdisk/test.jpg
  • 2
    How to take a bunch of fast timelapse pictures
    Let's say you want to use the raspberry pi to take a bunch of fast timelapse pictures (i.e., 1 second between pictures).
    First, you kick off the raspistill (this command will work with SSH too!)
    nohup raspistill -n -t 0 -o /mnt/ramdisk/test.jpg > /dev/null 2>&1 &
    Then, find out the PID with:
    pgrep raspistill
    Then, whenever you want a new picture to be taken, you use the "kill" command to send the message to raspistill to take a picture:
    kill -USR1 12125
    where 12125 is the PID you found using pgrep
    Then, you can rename the pictures or network copy them.  I think raspistill also takes in an incrementing filename.
    Don't forget to kill the raspistill process when you are done!  For example,
    kill 12125
View all instructions
sciencedude1990 wrote 04/03/2021 at 15:32 point
If you want to see what can be done with this setup, head on over to:
https://hackaday.io/project/178655-getting-cozy-with-the-diffraction-limit
