Notes 2021-03-24.pdf
Circuit diagrams and code mods for interfacing Z80 Tine BASIC to the terminal system.
Adobe Portable Document Format - 505.68 kB - 03/25/2021 at 08:49
Preview
Z80KB.ino
Arduino code for simple terminal program.
ino - 2.47 kB - 03/25/2021 at 08:48
Download
all.pdf
Personal notes from which the entire thing was built. These turned into the breadboard, and eventually the schematics and PCB in Eagle.<br><br>I used to generate boxes of notebooks with things like this in them. Now they&apos;re mostly stored electronically :)
Adobe Portable Document Format - 12.78 MB - 03/03/2021 at 23:21
Preview
The mostly-finished prototype. Lots of board capacitances/voltage drops/etc. but has worked remarkably well for a 4MHz circuit!
JPEG Image - 3.37 MB - 03/03/2021 at 22:43
Preview
Always a fan of wall art - this is the PCB layout (component side) for eventual assembly.
JPEG Image - 2.81 MB - 03/03/2021 at 22:43
Preview
Decided to make something more stable than a set of breadboards held together by wire and air lol. I started with an Arduino Mega 2560, since it had lots of IO...but eventually dialed it back to a standalone ATMega 328P with time-multiplexing of input signals.
JPEG Image - 3.66 MB - 03/03/2021 at 22:43
Preview
3.7V LiPo, recharging/load sharing system, and (eventually) 5V boost. Surprisingly, the Z80 runs fine on 3.7V. Most of the logic are 74HC series which are spec&apos;d that low.
JPEG Image - 3.58 MB - 03/03/2021 at 22:43
Preview
An earlier stage prototype, still driven by the giant AT2560.
JPEG Image - 3.75 MB - 03/03/2021 at 22:42
Preview
Since the Z80&apos;s opcode for NOP is 00, pulling the databus low will cause it to simply increment its address every 4 clock ticks. Easy way to get some blinking light satisfaction early in the process :)
JPEG Image - 3.39 MB - 03/03/2021 at 22:42
Preview
Moving away from the AT2560 to a AT328P; also adding a USBSerial solution. CP2102 has been my go-to, but supply issues, deprecated versions, QFN fun and pricetag sent me to the FTI-231, which works great!
JPEG Image - 3.70 MB - 03/03/2021 at 22:42
Preview
When I started, I was working on a pretty flimsy table with folding legs - fine for holding oil painting supplies, not so good for a workbench. After Corinna (my fianc&#xE9;e) got me a beautiful wooden toolbox for Christmas, I decided to upgrade my bench...so built a sturdy tabletop, stained it, and put it on a pair of saw horses. Works great!
JPEG Image - 2.86 MB - 03/03/2021 at 22:42
Preview
Z80 + SRAM...what else do you need? lol
JPEG Image - 2.96 MB - 03/03/2021 at 22:42
Preview
Once you&apos;re drilling holes in wood, you know your project is in great shape (either that, or maybe you&apos;re procrastinating!)
JPEG Image - 3.53 MB - 03/03/2021 at 22:42
Preview
Christmas present from Corinna. I&apos;d been working mostly out of cardboard boxes stacked on the floor.
JPEG Image - 3.35 MB - 03/03/2021 at 22:42
Preview
Yay for real switches!
JPEG Image - 2.93 MB - 03/03/2021 at 22:42
Preview
A finished board :)
Portable Network Graphics (PNG) - 1.70 MB - 03/03/2021 at 22:42
Preview
Gerber image of back of the board.
Portable Network Graphics (PNG) - 74.10 kB - 03/03/2021 at 22:42
Preview
Gerber image of front of board.
Portable Network Graphics (PNG) - 81.26 kB - 03/03/2021 at 22:42
Preview
Artwork for front of board.
Portable Network Graphics (PNG) - 77.23 kB - 03/03/2021 at 22:42
Preview
Original inspiration - the IMSAI 8080
JPEG Image - 22.31 kB - 03/03/2021 at 22:42
Preview
Got the first few LEDs working - half an address bus, etc.
JPEG Image - 3.33 MB - 03/03/2021 at 22:41
Preview
Pretty recent version (7 Feb 2021) of the breadboard-based system.
JPEG Image - 3.37 MB - 02/12/2021 at 21:19
Preview
