Works Great!
A project log for Pocket-Sized Imsai-Style Z80 Board
Similar to the old IMSAI 8080, but small enough to fit in your pocket :)
nickNick 03/03/2021 at 23:370 Comments
The board seems to be working perfectly! Building it up took me about 8 hours (I'm still relatively new to SMD work), and other than the few issues mentioned in the prior log, it all worked as expected.
I found that solder paste + hot air isn't as precise as hand-soldering for me, and some of the parts which are close to vias ended up shorting in the process. Hand soldering is more fun anyway :)
The 3D printed box I had made earlier worked out great.
