More Picture of the Beamboarder construction
A project log for The Beamboarder
Create a magnetic 4 watt high power LED head lamp for applications like longboards out of an old hard disk drive for less than 25 $.
lyonLyon 07/14/2014 at 17:070 Comments
Now that I realized that the smallest Version of the Beamboarder is ideal for skating around here some more pictures. Use some adhesive between the magnets to increase the heat transfer :
An small package of high power light. In the details you will find more informations about the how to build your own optic.
The material you will need for crafting the battery pack:
You can shrink all together with a lighter:
The voltage will stay at arround 9V and gently drop down. This is the perfect voltage for your LED.
