Definitive wiring
A project log for Picoth - 2FA Auth with Pi Pico
An easy to use yet secure 2FA gadget, using a Raspberry Pi Pico and RGB Keypad, MicroPython.
angainorAngainor 02/10/2021 at 10:310 Comments
I now consider the wiring definitive.
DS3231:
SDA to GPIO10 (i2c1)
SCL to GPIO11 (i2c1)
3V3 and GND taken from extra headers soldered on the keypad base.
RGB Keypad:
Default wiring, no change
Pico Display:
GPIO 16 (LCD_DC) and GPIO 20 (BL_EN) unchanged
Reset unchanged, as 3V3 and GND
LCD_CS connected to GPIO 21
LCD_SCLK to GPIO 26 (SPI1)
LCD_MOSI to GPIO 27 (SPI1)
Extras:
Buttons and RGB lines, that are on the opposite row can be wired as intended: they are not used by anything else.
Here is a preview of what it now looks like
https://twitter.com/Angainor15/status/1359431057611882498
*Update 2021-03-22. Fix wiring.
