Schematic diagram uploaded
A project log for 4017 Decade Logic Clock
A digital clock that displays the time using LED's numbered from zero to ten.
ian-dunnIan Dunn • 02/20/2021 at 19:47•0 Comments
Based on your feedback, (thank you!) I've uploaded the schematic diagram of this clock. If you'd like to try building it on your breadboard, it should work. Thank you!
