Uploaded updated schematic
A project log for 4017 Decade Logic Clock
A digital clock that displays the time using LED's numbered from zero to ten.
ian-dunnIan Dunn • 03/14/2021 at 22:36•0 Comments
This clock is nearly working. I soldered together the latest PCB, and it works pretty well except the seconds wouldn't advance the minutes, and the minutes wouldn't advance the hours. Long story short, I solved this by replacing a few 1n4148 diodes with some 4.3V zener diodes, and added a few small caps. if you build it on your breadboard, I won't say it will be easy but it should work!
