Raspberry PI case master BOM.odsThis is the master bill of materials. There's a lot of parts that went into this!spreadsheet - 17.04 kB - 02/09/2021 at 18:24 |
Power Button.stlThe power button. I recommend printing it in clear filament.Standard Tesselated Geometry - 53.01 kB - 02/09/2021 at 18:10 |
HDMI mount.stlThis is needed to hold a FPV HDMI cableStandard Tesselated Geometry - 33.58 kB - 02/09/2021 at 18:09 |
lid.stlLid with holes for a laptop sized SSD.Standard Tesselated Geometry - 211.12 kB - 02/09/2021 at 18:06 |
Lid No Holes.stlThe Lid without holes to mount a laptop hard driveStandard Tesselated Geometry - 129.28 kB - 02/09/2021 at 18:06 |
BOM_Raspberry Desktop_2021-02-09.csvBill of materials for the main PCB.Comma-Separated Values - 1.34 kB - 02/09/2021 at 18:04 |
Front PCB BOM.csvBill of Materials of the front PCB.Comma-Separated Values - 1.11 kB - 02/09/2021 at 18:04 |
Gerber_1-PCB_Front PCB_2021-02-09.zipThis is the Front PCB. It holds the power button, and front USB port.Zip Archive - 8.46 kB - 02/09/2021 at 18:02 |
Gerber_1-PCB_Main Board 2.zipThis is the main PCB that gives the case most of it's cool functions. You'll need to order it from a PCB fab house.Zip Archive - 71.45 kB - 02/09/2021 at 18:02 |
Schematic_Raspberry Desktop_FRONT.pdfSchematic diagram of the front PCBAdobe Portable Document Format - 15.31 kB - 02/09/2021 at 17:58 |
Schematic_Raspberry Desktop main board_2021-02-09.pdfSchematic diagram of the main PCBAdobe Portable Document Format - 44.27 kB - 02/09/2021 at 17:46 |
