Due Controller
A project log for Pi Pedalboard: Live/Recording Rig
A small pedalboard to enable home recording and performance during lockdown
craig-hissettCraig Hissett 10/27/2021 at 16:381 Comment
Just a quick update:
Still working out one or two audio issues with the Zoom interface; everything works, but there's a crackly digital sound over the mic sometimes. I have a feeling it may need the JACK settings fiddling with and dropping from 96k, or having the buffer increased.
That aside, the concept is working brilliantly; inputs can be routed via JACK into the effects software then into Reaper, as well as directly to Reaper. This allows me to record clean and effects simultaneously.
The Arduino Due has had a basic sketch put on it to send CC messages from the buttons on an LCD shield. It works, and has been tested with triggering Reaper transport controls.
This is coming along nicely.
Craig Hissett wrote 11/04/2021 at 17:45 point
Audio issues SOLVED! Running at 96k, but adjusted the buffer and another number from 2 to 3 and we have a stable sound!
I'm over the moon I've been able to get this reliably working. Next up is to adjust the script which assigns my effects outputs to the reaper inputs to start reaper and pause before assigning those routes, then run that on startup.
