The tinyjoypad is a fun exemple of how minimalist a 'game console' can be. The schematic is so simple, that a breadboard photo is enough, and the software is open (arduino). That sounded great !
I had some (dip8) attiny85 around, as well as the very famous small oled display, so it was very quick to get the breadboard implementation working, and my children urging me to let them play on it. But, well, breadboard is not good for actual playing.
There are some PCB variations on the web, and even on hackaday. You can get the gerbers, but not the schematics. Not as open as I would have liked. (I come from the software opensource community).
I needed to learn to make a PCB anyway, so here's my version. It has the following features:
- CR2032 holder for power supply. The console can support both usual cr2032 battery (~3V) and LiPo version (3.5~4.2 V). We use the LiPo battery and it's very useful. The console doesn't have any LiPo charging support though, you need an external charger.
- sound switch ( huge waf !)
- sound slightly lighter by lowering the voltage at audio speaker (again, huge waf !)
- use of 5-way joystick instead of tactile switches.
- standard ISP connector for changing games (aka reprogramming the MCU)
I also wrote a small interface to easily change the game on the console.
I did that before I was aware of this great project. The end-result is pretty similar. The 'tiny handheld' also has audio switch and ISP, and most importantly, the schematic is available (based on EasyEDA). It features an eeprom, not sure why.
It should accept any 'game' made for the tinyjoypad, including those by the original author, and others. Yevgeniy Olexandrenko did a great job gathering the binaries on his page.
The project was developed using KiCAD, all files are on the repository (schematics, PCB, and final gerbers for printing).
Launcher
On the repository, under the launcher/ directory, you can find a quick PyQt-based interface that display a grid of games, and will program the one you click on. You need to have PyQt installed (of course) and the ubiquitous avrdude programmer on the path. It's tested on Linux, but should work on any platform with PyQt and avrdude available. You can easily tweak the script to change the games list: you need a binary and an image for each game, all in the script directory. You may want to change the few messages displayed to 'users'. I put a screenshot in the gallery.
Programming
I use an USBasp programmer, but you can use anything you want. The connector on the board is extremely standard, and avrdude very probably support your programmer. Just change the settings on top of the script.
Charging
For charging the LiPo button batteries, I use those very very cheap TP4056-based chargers you can find on chinese sites, with a battery holder soldered directly. Works perfectly.
Compilation
Compiling even the original exemples is tricky. Here are the information I would have liked to find somewhere.
The 'games' are actually arduino sketches. But arduino 'as is' doesn't support bare attiny85. You need to instal a package (a BSP actually). The right one is https://github.com/damellis/attiny. Summary: you need to add an URL in File/Preferences/AdditionalBoardsManager, then select the righ package in Tools/Board/Boards Manager. Then configure in the new menu appearing: first the "board" ("Attiny/25/45/85"), then processor (85 obviously), then frequency ("Internal 16MHz").
That was the easy part. The tricky part is about the OLED driver. It's called 'ssd1306xled', but there are actually a lot of variations with this name. And most importantly, you'll find a library with such a name in the standard arduino packages manager. But this is not the right one. Using this standard one will create binaries very slightly bigger than the maximum size. Which is short, it's called 'tiny' for a reason.
The right one to use is
https://github.com/Defragster/ssd1306xled, and you copy/clone this under your arduino libraries directory, bypassing the interface installer. On linux that means ~/.Arduino/libraries/.
Weird values for resistors
To detect keys, the tinyjoypad uses resistor dividers and the internal ADC of the MCU. One on each direction (left/right, and up/down).
If you look at the schematic, you'll notice that the resistors values are weird. We would typically expect something like this to allow for maximum tolerance:
- voltage < vpp/3 : one direction
- voltage >2*vpp/3 : other direction
- otherwise no button is detected.
The reason for those strange values, which imho deserves an explanation, is that the left/right direction is wired to the PIN1 of the chip. The attiny85 is very limited on i/o, and we have to deal with the fact that pin1 is the reset pin. If the voltage is too low (say, less than half vpp), the chip will reset (or reboot). The good news is that if we stay on the upper half, we can still use the internal ADC, and that's what the original design takes advantage of. Hence those weird values..
Challenges
Designing the schematic and PCB was ok. We enjoy having those small joystick-like inputs, usually called "5-way switches". The main problem was to find proper components. Most of them were obviously easy (resistors.. even the oled). But at this time I have yet to find a proper "cap" for the joystick. It uses a very common/typical square 3.2mm axle, for which you can find cheap cap on the market. But they are too long/deep. We still rely on cutting them with a knife, which is ... unfortunate.
Replicating
It's easy for you to replicate this project. The easiest way is to use the provided gerbers and use one of the common "PCB printing" services. The parts are all standard and easy to find.
I've used SMD components, but only the biggest ones (1206). If you know how to solder through-hole components, it really is not more difficult. I did that for the first time and it went well.
I used through-components for the MCU (I only had those), and for the joystick (for mechanical reasons).
Bill of material
There's a bom.fods file on the repository. The overall cost is about 6€. The heaviest parts, and also those that most hobbyists probably already have are the OLED display, the attiny85 and the battery. Without those parts, the cost is around 2€, including the PCB.
I do not intend to provide kits on tindie or whatever. I have a few spare PCBs though, contact me if interested, especially if you happen to live near Paris/France.
Things to be aware of:
- joystick / 5-way switches: I've used no-name chinese components, but I guess they are based on a standard one (probably the SKQUCAA010 from Alps or Alpine brand). All those found on internet have the same characterics, most importantly the footprint, so there's not real risk here. Just be sure to use the through-hole version, there exists a surface one.
- OLED display: you can find them everywhere, but be careful that the wiring might be different. The PCB uses the (I thing) most common one with pins in this order: GND, VDD, SCK, SDA. You can find them with different colors, and my children enjoy being able to change the display color as they wish.
Random notes
There are holes on the PCB to fix the oled display using 11/12mm standoffs + screws. Unfortunately, the OLED modules you find are all different on this regard. Even the few I have are not compatible, and yours will probably be different. Anyway, you need to remove the display for changing the battery or the game. The idea was to 'harden' it slightly so that it could be brought to school.
