ATtiny13A PCB Star Wearable
A twinkly star PCB ornament
I've designed this tiny twinkly star for JLCPCB's Christmas decorations design challenge, but I only got to order & assemble it now, so I've repurposed it as a wearable for now.
This was just a fun and quick project, so it's super simple: the LEDs are controlled by an ATtiny13A microcontroller and powered by a 3V CR1225 battery. And it's only 4x4cm wide!
  • 1 × JLCPCB Customized PCB
  • 8 × 0603 2mA Amber LEDs
  • 4 × 0603 5mA White LEDs
  • 4 × 0603 5mA Blue/Purple LEDs
  • 1 × ATTINY13-20MMU Microcontroller Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
View all 8 components
  • 1
    PCB Order & Assembly
    I used Figma to create the star shape which I've exported to Eagle CAD using Gordon Williams' SVG to Eagle CAD converter.
    I ordered the PCBs from JLCPCB and assembled them myself. I was wondering if they'd be able to cut the PCB at such sharp angles and I'm actually pleased with how they look.
    Here's the top of the PCB:
    And here's the back:
    I've added 4 pads on the back, in case I want to solder some hooks on it to use it as a wearable. The detailed schematic and the Eagle CAD files are here
  • 2
    Programming
    I've placed the ISP pads on the back of the star in order to program the ATtiny using this DIY pogo-pins adaptor for my USBasp programmer (3.3V logic).
    I've used the MicroCore ATtiny13A core and (very important!) I've disabled the brown-out detection (BOD) when burning the bootloader. If it's set too high the LEDs won't turn on when the battery starts discharging. The code is also on Github.
  • 3
    Final product
    This is the finished product!
View all 3 instructions
Virtual_Burrito wrote 10/05/2022 at 11:23 point
I have a question about the LEDs you used for this awsome project.
For the 0603 2mA Amber LEDs. Did you use the Metric size or the Imperial size? Since i live in europe and the imperial 0603 is our 1608 metric size
