ns32016.pdfVince's NS32008 dev board schematic as a pdf.It is all in one sheet so it will be unreadable if printed on an A4. Even A3 requires some squinting. Adobe Portable Document Format - 102.50 kB - 02/24/2023 at 20:18 |
ns32016.schVince's NS32008 dev board schematic in Eagle format.x-kicad-schematic - 1.35 MB - 02/24/2023 at 20:18 |
ns32016.brdVince's NS32008 dev board layout in Eagle format.brd - 528.66 kB - 02/24/2023 at 20:18 |
ns32016-parts.txtVince's NS32008 dev board parts list.Some are missing values. plain - 17.13 kB - 02/25/2023 at 19:49 |
pc16550d.pdfThe UART datasheetAdobe Portable Document Format - 1.07 MB - 05/14/2022 at 00:06 |
2021-03-10-0003-landscape.jpgNS32008 PCB bottom side with bodge wiresJPEG Image - 16.93 MB - 05/13/2022 at 14:57 |
2021-03-10-0005-landscape.jpgNS32008 PCB top side with bodge wiresJPEG Image - 14.99 MB - 05/13/2022 at 14:57 |
2021-03-10-0003.pdfNS32008 PCB bottom side with bodge wiresAdobe Portable Document Format - 11.38 MB - 03/10/2021 at 12:57 |
2021-03-10-0005.pdfNS32008 PCB top side with bodge wiresAdobe Portable Document Format - 9.34 MB - 03/10/2021 at 12:57 |
NS32000_databook_1986-page-02-274.pngExample circuit from 32016 datasheet (the 32008 datasheet did not have one).Portable Network Graphics (PNG) - 59.39 kB - 03/10/2021 at 02:05 |
ALL-4Y062078.zipVince's NS32008 dev board files. He thinks the 'ok' folder was what they had to rename my files to to work in their production system. His original files are in the yg/1 folder.Zip Archive - 6.66 MB - 03/10/2021 at 01:58 |
Acorn BBC BASIC for the NS32000 manual in html form.zipBBC BASIC manual, in html form. Corrects some errors from the pdf version. Hyperlinked contents page so it is quick and easy to navigate.Zip Archive - 18.30 kB - 03/02/2021 at 18:52 |
NS32008-10-datasheet.pdfDatasheet for 10 MHz deviceAdobe Portable Document Format - 2.95 MB - 02/19/2021 at 00:39 |
