Large DIY 3D Printer With All Lead Screw
Large DIY 3D Printer Build: All Lead Screw 3D Printer With Fixed Bed / Moving Gantry
Public Chat
DIY Large Scale 3D Printer With All Lead Screws
The Workhorse Printer is a large format 3d printer some friends and I have been working on for the past three years. The large 3d printer is a modular machine platform that uses lead screw driven motion with a fixed bed / moving gantry.
  • Fixed Bed / Moving Gantry
  • X and Y-Axis Lead Screw
While most 3d printers use belt driven motion in the x and y axis to increase print speed but loses quality when more weight is applied to the gantry or carriage. The lead screw used on the Workhorse has a high helix pitch with multiple threads to allow increased print speeds while maintaining the quality provided from lead screw and ball screw motion. We designed the machine for applications that require more weight to the gantry or carriage such as materials such as clay, chocolate, plastic pellet extrusion. The increase weight that is moved
around which without decreased quality or reduced print speeds.
Lead Screw vs Belt Driven Motion
While most 3d printers use belt driven motion in the x and y axis to increase print speed but loses quality when more weight is applied to the gantry or carriage. The lead screw used on the Workhorse has a high helix pitch with multiple threads to allow increased print speeds while maintaining the quality provided from lead screw and ball screw motion. We designed the machine for applications that require more weight to the gantry or carriage such as materials such as clay, chocolate, plastic pellet extrusion. The increase weight that is moved  around which without decreased quality or reduced print speeds.
Large Build Area
Large Scale 3D Printing
  • Print size millimeters (xyz): 650 x 350 x 350 mm
  • Print size inches (xyz): 25.6 x 13.7 x 13.7 inches
Fixed Bed
While most large format printers use a moving bed that moves along the Z-Axis, the Workhorse’s fixed bed and moving gantry design is more ideal for the large scale 3d printing process.
Nema 23 Stepper Motors
In order to drive the lead screw we had to use Nema 23's instead of the typical Nema 17 stepper motors found on most 3d printers and machine custom motor mounts.
Carriage & Gantry Design
WorkHorse X-Carriage
Duet Wifi and Duet 3 Mainboard
Hackaday 3d Printer Project Lists
Large Scale 3D Printers
CoreXY 3D Printer
SolidCore 3D Printer
Gantry Assembly
Mic6 Aluminum Build Plate
WorkHorse 3D Printer Heated Bed
Carriage Assembly
Igus Lead Screw
Duet3D Firmware
We now recommend the Duet 3 Mainboard 6HC electronics by Duet3D. Build & Firmware Updates
Workhorse Specifications
  • Technology: FFF FDM
  • Type: Material extrusion
  • Open-Source Year: 2018
  • Assembly or DIY Kit
  • Mechanical arrangement: Cartesian-XYZ-Head
  • Manufacturer country: USA
Materials
  • Filament diameter:1.75 mm, 3mm
  • Compatible with 3rd party filaments? Yes an open material system
  • Printable material(s):ABS, CPE, HIPS, Nylon, PETG, PLA
x-zip-compressed - 11.99 MB - 03/10/2021 at 21:14
Download
step - 16.29 MB - 03/10/2021 at 21:13
Download
f3z - 7.27 MB - 03/10/2021 at 21:13
Download
  • 2 × Gantry Plates
  • 1 × Nema 23 Motor Mount
  • 7 × MGN12 Linear Rails
  • 3 × Nema 23 Stepper Motors
  • 4 × Nema 17 Stepper Motors
  • Y-Carriage Design Update
    Shane Hooper02/27/2021 at 03:04 0 comments
    • Reduced the weight and footprint of the Y-Axis Carriage.
    • Experimenting with Igus anti backlash lead screw nuts.
    • Trying out different direct drive extruder designs
    I'm considering making the X and Y-axis C-Carriage designs from solid rectangular bar instead 2" x 4" aluminum tubing. There will be a increase in wasted and machine time but the over all weight and footprint will decrease. The more compact design will allow faster printing speeds due to reduced deflection within the system.
View project log
  • 1
    Step 1
  • 2
    Frame
  • 3
    Heated Bed
View all 5 instructions
Starhawk wrote 04/28/2021 at 00:17 point
Hey -- in the Project Details, the paragraph that starts "While most 3d printers [...]" is duplicated, and the first copy has a line break in the wrong place at one spot. Just FYI ;)
I hate typso like that... they suck!
Starhawk wrote 04/28/2021 at 00:18 point
(Yes I did that on purpose. I'm a wise*** like that!)
Shane Hooper wrote 02/22/2021 at 01:09 point
Thanks Starhawk!
Starhawk wrote 02/21/2021 at 08:39 point
+Like and +Follow!
Also, check your Chat / Private Messages / "DM"s / etc ;)
