X-Carriage Design
A project log for Large DIY 3D Printer With All Lead Screw
Large DIY 3D Printer Build: All Lead Screw 3D Printer With Fixed Bed / Moving Gantry
shane-hooperShane Hooper 10/05/2021 at 07:060 Comments
WorkHorse 3D Printer X-Carriage Design
The Workhorse Gantry and Carriage design is a heavy-duty solution for lead screw/ball screw motion. I have a newer design that's a little lighter but I haven't tested it out yet.
X-Carriage Assembly
X and Y-Carriages use 4 M3x6mm Screws
The x-axis carriage screws down to the 2040 Y-axis extrusion and rail. *Note* The y-axis 2040 extrusion must have hand tapped M5 threaded holes.
X-Carriage Design Diagram
Linear Rails
The Workhorse Printer uses MGN12H linear rails with a 20mm x 20mm Hole Pattern.
Igus Lead Screw Drive Mechanism
