One of my impulse purchases of 2020 was a sizeable amount of used servos from Aliexpress. I bought two types, and they appear to be very similar in many ways.
This project documents my effort to find a way to control them.
Guys and girls! I found where they come from! But no way I'm going to spend 1200USD-3000USD with the robot to test them... (details in a few!)
UBTECH have many diferent robots and doing image search of their robots i found this (on just two webpages), look closely to the arms...
The servos looks exactly like ours!!! So I well think that this cheap servos from Aliexpress are from units not sold, because of the high price for such a small device to learn. I only found it to buy here:
After this robot was made, probably this one was developed, it's called ALPHA MINI! It's such a great pece of art! Front camera, two LCD screens as eyes, IA, and much more!
I wonder if what found "Nick777 on the #27 coment" can be implemented with the Mini, as it was for the ALPHA 2 robot and this looks like the next version.
I think I found him, but I cannot send him a message via Twitter. I made a tweet, let's see if he can answer "us".
There could be many many more motors around! Next steps: try to implement this plugin fro the ALPHA servos with the EZ-B! (I don't think I'll buy one, as it's really expensive (shipping cost) for me. I'll try to use the halfduplex code for Arduino from above)
Baud rate:115200 Data bit:8 Stop:1 Check:0 Flow control:NONE TTL multi-layer connection,shared-bus ID:1-240 Feedback:position:deviation adjustment,version information
Serial parameter:115200,8,n,1,1
Protocol analysis
EMBEDDED LED // FA AF 01 04 00 00 00 00 05 ED switch on led light // no LED on mine // FA AF 01 04 01 00 00 00 06 ED switch off led light// no LED on mine RESPONSE AA + id // not tried yet as I cannot see with my proto board
GET VERSION FC CF {id} 01 00 00 00 00 {sum} ED // not tried yet RESPONSE FC CF {id} {V-1} {V-2} {V-3} {V-4} {sum} ED this can be used to check if servo exist in a loop "for id"
MOVE servo // FA AF {id} 01 {angle} {time} {T1} {T2} {sum} ED whre T1=0 and T2= {time}= TIME to execute in ms / 20 0 to 255(FF) ie 5.12 second to execute RESPONSE AA + id // not tried yet as I cannot see with my proto board
GET POSITION // FA AF {id} 02 00 00 00 00 {sum} ED // not tried yet REPONSE FA AF {id} 00 {angle} 00 {real} {sum} ED // not tried yet as I cannot see with my proto board
SET OFSET ANGLE // FA AF {id} D2 00 00 {A1} {A2} {sum} ED where A1 adjValue/256 and A2 adjValue%256 // not tried yet RESPONSE FA AF {AA + id} 00 00 00 00 {sum} ED
GET OFSET ANGLE // FA AF {id} D4 00 00 00 00 {sum} ED // not tried yet RESPONSE FA AF {AA + id} D4 00 00 {A1} {A2} {sum} ED where A1 adjValue/256 and A2 adjValue%256
I got the small servo and it uses an "ATMEL SAMD10U 822B TW 18224YS" main board (looks like "SAM D10D 24-pin QFN" to me from the datasheet) and the chip on the back side is an "MPJJ 6515 800". But I could not find any datasheet.
SAM D10 datasheet pinout:
At the side of the board is written: " 2KG_D10YS_V0_04 PCB".
Sharing some new pictures here:
I'm reverse engineering the circuit to see if we can work with it.
Future work, check the compatibility with this codes:
The first type I bought here for $2.31 apiece, including shipping.
The second one from the same seller was slightly cheaper.
Description of both mentions that they are used, untested, and the seller does not know how to control them. There is no mention of brand or datasheet.
Even though these are no longer available, you can still find similar used servos, like this one.
While the larger servos have no branding, the smaller ones have UBTECH name on two sides. This name eventually leads to their offering of small servos. And here we go.
There is a table with some basic parameters, a dimensional drawing, and a datasheet for each servo. I could not open the datasheet, so I'm stuck with whatever info I can get without it.
To illustrate some parameters, here's a rough comparison with SG90. There is a lot of variety when it comes to SG90 so take these figures with a grain of salt.
Parameter
SG90
2kg UBTECH
3kg UBTECH
Weight
9 g
12 g
20.4 g
Operating voltage (DC)
4.8-6V
6-10V
6-10V
Maximum torque
1.2kg*cm@4.8V
2kg*cm@7.4V
3kg*cm@7.4V
Maximum speed (no load)
0.15s/60°@4.8V
0.31s/60°@7.4V
0.28s/60°@7.4V
Rotation range
180°
240°
360°
Rotation accuracy (no load)
3°?
1°
0.7°
Maximum working current
0.6A
0.2A
0.25A
Aliexpress description offers a rough outlook of the insides, but I took them apart to understand better what is behind the specs.
The larger 3kg servo has a magnetic encoder and Cortex-M0+ microcontroller. The board with motor is available without the shell for about a dollar on Aliexpress too(here). So when I eventually burn something, replacement is very cheap.
The smaller one uses a potentiometer for feedback. Here I couldn't identify any ICs. Here the board with the motor is also available for cheap.
Now that I have some idea of what I'm working with, I can start searching for a way to control them.
Hello! That's interesting, I've gotten something similar from Aliexpress here: https://www.aliexpress.com/item/4000812945837.html
This particular model uses a ATMEL ATMEGA8A as its controller.
I wonder if we can find out the schematic/diagram of the boards and flash a custom firmware into the controller?
I have tried using a Hiwonder/LewanSoul/LOBOT BusLinker v2.5 I got off Amazon to try to control it, but the software for the BusLinker does not see any of the servos. I've also tried using a ESP32 board with the LX-16A Arduino library, but the servo did not respond. At this point I am not sure if the servos I bought even works at all.
On the side of the board is written: " 2KG_D10YS_V0_04 PCB".
Added a Log with the board pictures. Also found this reverse engineered code for the Alpha servos, may work with this one? https://synthiam.com/Community/Questions/Control-UBTech-Alpha-Servos-With-The-Ez-b-V4-3932/comments with this plugin: https://synthiam.com/Support/Skills/Servo/UBTECH-Alpha-Servos-UBT-12HC?id=16022
try poking at it with the I2c scanner on an arduino
