Some more info
A project log for Cracking comms for a cheap Chinese servos
finding a way to control a servo without any datasheet
eloivilaltaEloiVilalta 03/30/2022 at 21:033 Comments
I got the small servo and it uses an "ATMEL SAMD10U 822B TW 18224YS" main board (looks like "SAM D10D 24-pin QFN" to me from the datasheet) and the chip on the back side is an "MPJJ 6515 800". But I could not find any datasheet.
SAM D10 datasheet pinout:
At the side of the board is written: " 2KG_D10YS_V0_04 PCB".
Sharing some new pictures here:
I'm reverse engineering the circuit to see if we can work with it.
Future work, check the compatibility with this codes:
https://github.com/Super169/UBTech/blob/master/UBTech.cpp
https://alexsonea.com/2017/10/15/jimu-hacking-the-communication-protocol/
Codes of the findings above can be found here:
https://synthiam.com/Community/Questions/Control-UBTech-Alpha-Servos-With-The-Ez-b-V4-3932/comments
Per Jensen wrote 04/03/2024 at 09:17 point
The "unknown" chip is a MP6515 H-bridge motor driver from MPS. https://www.monolithicpower.com/en/mp6515.html
txyz.info wrote 01/08/2023 at 17:53 point
same here good job!
cbruner wrote 08/09/2022 at 22:36 point
I've got some of these on their way. Glad to have found your page. Hopefully we can figure it out :)
