An Interpreter, for C++?
Yes. Despite it's widely known that C++ is an AOT language, such an amazing thing as a C++ interpreter does exist. It's cling developed by Root Team of CERN on the top of LLVM and Clang. You may have played with some toy-like C interpreter already, but cling is a sophisticated project with all features a modern REPL for a regular script language is supposed to have, such as stack trace, variable shadowing and statement value echo back.
It's a shame that the official builds for cling are only available for x86/64 platforms currently, however, I managed to build it for the armhf (arm v7) architecture with a QEMU+chroot environment. Here is the repository containing the build script and a pre-compiled binary in release:
https://github.com/SdtElectronics/cling-build
Sonuds Interesting, But Why Bother?
Cling is one of the most imaginative projects I have ever seen. How useful it is depends on how creative you are. But here I'd like to specially address on its usage on embedded development. Accessing peripherals on a SoC is essentially wrapped by system calls, and only language can handle this easily is C. The compatibility with C of cling makes it able to execute system calls directly, which essentially implies you can do anything (allowed in user space) with it, dynamically and interactively. Granted, there are frameworks like microPython which allows you to interact with peripherals dynamically as well, but this is limited to those APIs already wrapped by the framework. In comparison, you can do anything a C program can do in user space with cling. Additionally, some performance-sensitive applications are preferably written in C/C++, and a REPL is desirable for fast-prototyping and debugging.
The text wall is tiresome. Let's see an example demonstrating interact with the new GPIO API, libgpiod, dynamically with cling:
A Quick Start for Cling
hello world:
[cling]$ #include <stdio.h>
[cling]$
[cling]$ printf("hello world\n");
hello world
You can include all headers contained in the search path of your system, including kernel headers. All symbols are ready to use after the include statement.
Echo Values of Statements:
What if you omit the semicolon at the end of a statement? Will you get an error? No, cling will echo the value of that statement in this condition. People have worked with matlab may feel familiar with this: If the ending semicolon isn't omitted, the echo in the console will be disabled, otherwise the echo will be printed:
[cling]$ __cplusplus
(long) 201703
Cling can echo statements of some objects and their references analytically. The supported objects are mainly STL containers:
[cling]$ #include <string>
[cling]$
[cling]$ std::string {"str"}
(std::string) "str"
[cling]$
[cling]$ #include <vector>
[cling]$
[cling]$ std::vector<char> ve{'c', 'h', 'a', 'r'}
(std::vector<char> &) { 'c', 'h', 'a', 'r' }
[cling]$
[cling]$ #include <map>
[cling]$
[cling]$ std::map<int, char> mp{std::pair<int,char>()}
(std::map<int, char> &) { 0 => '0x00' }
Names of functions are also statements. What values will be echoed for them?
[cling]$ atoi
(int (*)(const char *) throw()) Function @0xb6c7bcd1
at /usr/include/stdlib.h:104:
extern int atoi (const char *__nptr)
__THROW __attribute_pure__ __nonnull ((1))
It's the signature of the function!
I enabled RTTI in my build script, so the dynamic inspection of types by typeid is also supported:
[cling]$ auto b = std::string ("typed")
(std::basic_string<char, std::char_traits<char>, std::allocator<char> > &) "typed"
[cling]$ typeid(b).name()
(const char *) "NSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE"
To convert this mangled type name to readable text, you may want to use c++filt:
c++filt _ZNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE
std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >
Advanced Usages
Loading Files
Except standard C++ syntax, cling supports some internal commands as well. These commands are started with a dot, and you may have already used one of them to quit cling: ".q".
Let's see a command supporting load of external source files: ".L"
# echo 'int val = 42;' > tst.cpp
# ./cling
****************** CLING ******************
* Type C++ code and press enter to run it *
* Type .q to exit *
[cling]$
[cling]$ .L tst.cpp
[cling]$ val
(int) 42
The symbols in loaded files are ready to use now. Notice that cling can NOT handle the dependency of source files loaded for you (it don't know where the dependencies are, apparently), thus if the loaded files depend on other files, you need to load them manually.
A similar command is ".x". It loads the designated file as well, however, if a function inside has the same name as the file, that function will be called immediately after loading:
# echo 'int tst(){return 42;}' > tst.cpp
# ./cling
* Type .q to exit *
[cling]$
[cling]$ .x tst.cpp
(int) 42
One of the incredible features of cling is it can also load shared libraries (.so)! Notice that you'll need to include the corresponding headers to make the symbols in them accessible:
[cling]$ #include <gpiod.hpp>
[cling]$
[cling]$ .L /usr/lib/arm-linux-gnueabihf/libgpiod.so.2
[cling]$
[cling]$ .L /usr/lib/arm-linux-gnueabihf/libgpiodcxx.so
[cling]$
[cling]$ gpiod::chip chip("/dev/gpiochip0")
(gpiod::chip &) @0xb6fa100c
[cling]$
[cling]$ auto lines = chip.get_line(236)
(gpiod::line &) @0xb6fa1014
[cling]$
[cling]$ lines.request({.consumer = std::string("tst"),
[cling]$ ?
[cling]$ ? .request_type = gpiod::line_request::DIRECTION_OUTPUT,
[cling]$ ?
[cling]$ ? .flags = gpiod::line_request::FLAG_OPEN_DRAIN})
[cling]$
Miscellaneous Commands
".I" which adds or prints include searching paths:
[cling]$ .I
-cxx-isystem
/usr/include/c++/10
-cxx-isystem
/usr/include/arm-linux-gnueabihf/c++/10
-cxx-isystem
/usr/include/c++/10/backward
-isystem
/usr/local/include
-isystem
/home/cling-src/release/bin/../lib/clang/5.0.0/include
-extern-c-isystem
-extern-c-isystem
/include
-extern-c-isystem
/usr/include
-I
/home/cling-src/release/include
-I
/home/cling-src/llvm/tools/cling/include
-I
-resource-dir
-nostdinc++
".class", a powerful command which prints the layout of specified class:
[cling]$ #include<limits>
[cling]$
[cling]$ .class std::numeric_limits<char>
struct std::numeric_limits<char>
SIZE: 1 FILE: limits LINE: 453
List of member variables --------------------------------------------------
limits 455 0x0 public: static constexpr _Bool is_specialized
limits 468 0x0 public: static constexpr int digits
limits 469 0x0 public: static constexpr int digits10
limits 471 0x0 public: static constexpr int max_digits10
limits 473 0x0 public: static constexpr _Bool is_signed
limits 474 0x0 public: static constexpr _Bool is_integer
limits 475 0x0 public: static constexpr _Bool is_exact
limits 476 0x0 public: static constexpr int radix
limits 484 0x0 public: static constexpr int min_exponent
limits 485 0x0 public: static constexpr int min_exponent10
limits 486 0x0 public: static constexpr int max_exponent
limits 487 0x0 public: static constexpr int max_exponent10
limits 489 0x0 public: static constexpr _Bool has_infinity
limits 490 0x0 public: static constexpr _Bool has_quiet_NaN
limits 491 0x0 public: static constexpr _Bool has_signaling_NaN
limits 492 0x0 public: static constexpr enum std::float_denorm_style has_denorm
limits 494 0x0 public: static constexpr _Bool has_denorm_loss
limits 508 0x0 public: static constexpr _Bool is_iec559
limits 509 0x0 public: static constexpr _Bool is_bounded
limits 510 0x0 public: static constexpr _Bool is_modulo
limits 512 0x0 public: static constexpr _Bool traps
limits 513 0x0 public: static constexpr _Bool tinyness_before
limits 514 0x0 public: static constexpr enum std::float_round_style round_style
List of member functions :---------------------------------------------------
filename line:size busy function type and name
(compiled) (NA):(NA) 0 public: static constexpr char min() noexcept;
(compiled) (NA):(NA) 0 public: static constexpr char max() noexcept;
(compiled) (NA):(NA) 0 public: static constexpr char lowest() noexcept;
(compiled) (NA):(NA) 0 public: static constexpr char epsilon() noexcept;
(compiled) (NA):(NA) 0 public: static constexpr char round_error() noexcept;
(compiled) (NA):(NA) 0 public: static constexpr char infinity() noexcept;
(compiled) (NA):(NA) 0 public: static constexpr char quiet_NaN() noexcept;
(compiled) (NA):(NA) 0 public: static constexpr char signaling_NaN() noexcept;
(compiled) (NA):(NA) 0 public: static constexpr char denorm_min() noexcept;
Finally, " .help" command which prints all available (not really, some commands hinted in the ROOT prompt seem to be omitted here) commands and their corresponding usages:
[cling]$ .help
Cling (C/C++ interpreter) meta commands usage
All commands must be preceded by a '.', except
for the evaluation statement { }
Syntax: .Command [arg0 arg1 ... argN]
.L <filename> - Load the given file or library
.(x|X) <filename>[args] - Same as .L and runs a function with
signature: ret_type filename(args)
.> <filename> - Redirect command to a given file
'>' or '1>' - Redirects the stdout stream only
'2>' - Redirects the stderr stream only
'&>' (or '2>&1') - Redirects both stdout and stderr
'>>' - Appends to the given file
.undo [n] - Unloads the last 'n' inputs lines
.U <filename> - Unloads the given file
.I [path] - Shows the include path. If a path is given -
adds the path to the include paths
.O <level> - Sets the optimization level (0-3)
(not yet implemented)
.class <name> - Prints out class <name> in a CINT-like style
.files - Prints out some CINT-like file statistics
.fileEx - Prints out some file statistics
.g - Prints out information about global variable
'name' - if no name is given, print them all
.@ - Cancels and ignores the multiline input
.rawInput [0|1] - Toggle wrapping and printing the
execution results of the input
.dynamicExtensions [0|1] - Toggles the use of the dynamic scopes and the
late binding
.printDebug [0|1] - Toggles the printing of input's corresponding
state changes
.storeState <filename> - Store the interpreter's state to a given file
.compareState <filename> - Compare the interpreter's state with the one
saved in a given file
.stats [name] - Show stats for internal data structures
'ast' abstract syntax tree stats
'asttree [filter]' abstract syntax tree layout
'decl' dump ast declarations
'undo' show undo stack
.help - Shows this information
.q - Exit the program
Notes on Serial Devices
It seems that cling would print characters not compatible with a serial console. In case you find problem using it on a device connected via a serial port, try out command below which executes cling within a wrapper:
script -qc ./cling | cat
