Soil Moisture and Temperature sensor SMT-01
The sensor design is based on the dependence of the rate of dissipation of thermal energy on soil moisture
Public Chat
Starting from
$5.00
greensensors has 2 orders / 0 reviews
Ships from Ukraine
SMT-01 is designed to measure soil moisture and temperature for monitoring and automatic irrigation systems. SMT-01 has a waterproof housing. SMT-01 provides measurement of parameters in a wide temperature range and in soils of different composition with high stability. SMT-01 is compatible with various microcontrollers, and the shielded cable allows data transmission up to 30 m.
Main technical characteristics:
Supply voltage: 3.3 - 5.0 V.
Current consumption in measurement mode: less than 150 mA.
Standby current consumption: less than 2 mA.
Measurement time: 7-12 minutes.
Measurement error: less than 2.5%.
Sensor dimensions: 40x9x9 mm.
Connecting cable length: up to 30 m.
Design description, examples of electrical connection of the sensor and software for Arduino and ESP8266 microcontrollers on github: https://github.com/greensensors/SMT-Soil-Moisture-Sensor-for-Arduino.
Additional information: greensensorso@gmail.com
Adobe Portable Document Format - 513.20 kB - 03/07/2021 at 15:19
Preview
Download
SMT-description-Part2.pdf
SMT-01 Practical Guide
Adobe Portable Document Format - 1.10 MB - 02/22/2021 at 10:38
Preview
Download
