Some housekeeping done...
A project log for Adria - A 65C816 based computer
Adria is a WDC65C816 based computer, inspired by RC2014. Main goal is to create a DIY friendly computer
xander-maasXander Maas 02/24/2021 at 16:390 Comments
Received the v2.0 version of the backplane. The backplane is now 4-layer, with ground and power planes as layer 2 and 3. I forgot to remove the ground-fill on the bottom layer, let's see how that works out.
Also published the project files on GitHub and write down the memory map (as it is right now) in the project details.
