SolarSens is a modular weather station.
It can be equipped with various sensors. Sensors, which also have to be illuminated by sunlight, can be installed waterproof on the "sensor phalanx" above the solar cell on the outside. This way brightness and UV exposure can also be measured.
Additional sensors can be installed inside the weather station (for example temperature and humidity sensors). In addition, an SDS011 can be "piggybacked" on the back of the housing.
The solar cell on the front supplies the electronics with energy and charges the built-in 18650 LiPo cell.
The measured data can be sent to your own SmartHome using WiFi.
I am currently working on a new circuit board, which should enable the data to be forwarded via LoRa and / or gsm.
Support:
If you want to support me, you can do so by like on this project page, on Instagram or by donating a coffee. :)
Licenses:
Content that is not based on software/code: Unless otherwise stated, all works presented here that are not based on software/code are subject to the CC BY-NC-SA 4.0 license (attribution – non-commercial – dissemination under the same conditions 4.0 international).
You can find a summary here: https://creativecommons.org/licenses/by-nc-sa/4.0/deed.de
You can find the complete legal text here: https://creativecommons.org/licenses/by-nc-sa/4.0/legalcode.de
Software/code-based works Unless otherwise stated, all software/code-based works presented here are subject to the GNU Affero General Public License v3.0
You can find a summary here: https://tldrlegal.com/license/gnu-affero-general-public-license-v3-(agpl-3.0)#summary
The complete legal text can be found here: https://www.gnu.org/licenses/agpl-3.0.de.html
