Mandelbrot on Pi Pico
Every platform needs a Mandelbrot
CircuitPython code is below.
First CircuitPython version: https://github.com/hwiguna/PicoMandelbrot
Latest MicroPython version: https://github.com/hwiguna/HariFun_202_MandelbrotPico
View all 2 project logs
  • 1
    mandelbrot.py
    MAX_ITER = 80
    def mandelbrot(c):
        z,n = 0,0
        while abs(z) <= 2 and n < MAX_ITER:
            z = z*z + c
            n += 1
        return n
  • 2
    mandelHari.py
    # Mandelbrot adapted for Pi Pico by Hari Wiguna from:
    # https://www.codingame.com/playgrounds/2358/how-to-plot-the-mandelbrot-set/mandelbrot-set
    def main():
        import board            # Pi Pico Board GPIO pins
        import displayio        # Python's multi layer graphics
        import adafruit_displayio_ssd1306   # OLED Driver
        import busio            # Provides I2C support
        import time
        from adafruit_display_shapes.line import Line
        import math
        from hari.mandelbrot import mandelbrot, MAX_ITER
        WIDTH, HEIGHT = 128, 64 #32  # Change to 64 if needed
        displayio.release_displays() # Just to be safe
        def SetupDisplay():
            # So we can communicate with our OLED via I2C
            i2c = busio.I2C(scl=board.GP3, sda=board.GP2)
            #while not i2c.try_lock():
            #    pass
            #print("i2c address is = ",i2c.scan())
            # How displayio talks to physical screen
            display_bus = displayio.I2CDisplay(i2c, device_address=60) # was 0x3A, reset=oled_reset)
            # display represents the physical screen
            display = adafruit_displayio_ssd1306.SSD1306(display_bus, width=WIDTH, height=HEIGHT, auto_refresh=False)
            # Group is a list of TileGrids that display would render on physical screen
            group = displayio.Group(max_size=1)
            display.show(group)
            return (display, group)
        def SetupTileGrid():
            #-- Create a bitmap --
            bitmap = displayio.Bitmap(WIDTH, HEIGHT, 2)
            #-- Create Palette --
            palette = displayio.Palette(2)
            palette[0] = 0
            palette[1] = 0xFFFFFF
            #-- Create TileGrid --
            tileGrid = displayio.TileGrid(bitmap, pixel_shader=palette)
            return bitmap, tileGrid
        #=== MAIN ===
        (mDisplay, mGroup) = SetupDisplay()
        (mBitmap, mTileGrid) = SetupTileGrid()
        mGroup.append(mTileGrid) #add the TileGrid to the group
        RE_START = -1.5 #-2
        RE_END = -1 #1
        IM_START = -.25 #-1
        IM_END = .25 #1
        xOffset = -0.8
        RE_START = -2 + xOffset
        RE_END = 2 + xOffset
        IM_START = -1
        IM_END = 1
        MAX_ITER = 80
        for x in range(0, WIDTH):
            xx = RE_START + (x / WIDTH) * (RE_END - RE_START)
            for y in range(0, HEIGHT):
                yy = IM_START + (y / HEIGHT) * (IM_END - IM_START)
                c = complex(xx, yy) # Convert pixel coordinate to complex number
                m = mandelbrot(c)   # Compute the number of iterations
                color = 1 - int(m/MAX_ITER)
                if color>0: mBitmap[x,y] = 1 # Plot the point
            if x % 4 == 0: mDisplay.refresh()
        mDisplay.refresh()
        while True:
            pass
View all instructions
Hari Wiguna wrote 02/27/2021 at 14:21 point
OMG! That's impossible!? I suppose, it's "just" a specialized version of discrete logic computers. Looking forward to the article.
Dan Maloney wrote 02/26/2021 at 18:05 point
I agree -- every platform needs a Brot. Nice job here.
I stumbled across a Mandelbrot generator made completely with logic gates. It was done entirely within a logic simulator, but it should be possible to build a hardware version from discrete 74xx series chips. I'd dearly love to do that.
Watch for this week's Link's article for more info.
