Motion Control
A project log for Alt/Az Antenna Rotator from Pan/Tilt Camera Mount
Turn a COTS, Heavy duty pan/tilt camera mount into a functional satellite tracking Alt/Az mount for use with Hamlib
jrsphotoJrsphoto 02/25/2021 at 03:280 Comments
I mentioned that I plan on using the Onstep telescope motion control system to handle motion control for this rotator
Howard, the creator of Onstep, has quite a few models available, this one is the MiniPCB v2. and the processor can either be a Teensy 3.2 or 4.  I've got a Teensy 4 in there as that's what I have.   He also has a lot of options for stepper motor drivers.  Just change the code to suit.
Limit switches are connected to the 3.5mm mini stereo jack on the bottom right.
What does this get me?  A few things.  One is, its use of an advanced version of Mead's LX200 protocol.  That means  theory at least, I could track satellites with something like kStars& ekos.  Lots of power in those two systems.
