Supermicro to ATX Power Supply Adapter
Mount a redundant Supermicro PSU in an ATX chassis
Public Chat
This project was built specifically to fit a Fractal Define S2 chassis.  The Define S2 chassis is both long enough and has a mount on the bottom for a 240mm radiator.  This radiator mount is repurposed to be a mounting point for the PSU adapter.
Everything you see here was printed using a Prusa MK3s and Prusament PETG filament.  Every piece of this design prints well without any supports.  If you print a single copy of each object, you will probably exhaust an entire 1 Kg spool of filament.
  • 1
    Purchase and strip the Supermicro Power Distribution Board (PDB)
    Go out to eBay and find this PDB:  Supermicro PDB-PT825-36824 SC825.  It features three GPU power cables.  Each GPU cable has a one 8-pin and one 6+2 pin connector.
    After this PDB arrives, strip off the metal plate.  You won't need it.
  • 2
    Purchase two Supermicro power supplies
    The Supermicro PDB-PT825-36824 is a "23-pin" model and will accept both the 23-pin supplies and the 19-pin supplies.  This is not an exhaustive list, but just the various models that I had sitting at home that I know fit into the PDB-PT825-36824.
    23-Pin Model Numbers
    19-Pin Model Numbers
    If you choose to find a model that is not listed above, you should start by looking at the Supermicro Power Supply Matrix.  The only supplies that will physically fit have these dimensions:
    • Length (mm) = 336
    • Width (mm) = 76
    • Height (mm) = 40
    Unfortunately, the matrix doesn't tell you which supply is 19-pin and which is 23-pin.  However, if you do a Google search like this:
    "PWS-1K28P-SQ" site:supermicro.com
     Then you will get as your top hit this link:  https://store.supermicro.com/1280w-1u-pws-1k28p-sq.html
    Scroll down to the 'Detailed Specification' tab, then look for "Output Type    Gold Finger (23 Pair Connector)".
    I am using two PWS-1K28P-SQ supplies:
  • 3
    Purchase an ATX power cable extension kit
    If you look at Step #1, you will notice how the 24-pin and dual EPS12V cables are extremely short.  If your motherboard has its 24-pin connector at the top of the board, you will need a 50 cm extension.  If your motherboard has its 24-pin connector on the side, a 30 cm cable will work.
    I purchased a 50 cm extension kit because my ASUS Pro WS x570-ACE motherboard has a single EPS12v connector on top.
    My cable extension kit:  Amazon - LINKUP
View all 25 instructions
