PC 140mm Air Filter
Keep your case free from dust, hair, and grime!
Public Chat
Motivation:
I hate cleaning computer cases.  I've seen dust bunnies the size of gerbils.  Being an engineer, I decided to do something about it.
Filters on the Market:
If you were to go looking, you will find two common types of computer air filters for purchase:  mesh and open cell foam.
Both mesh and foam let the small stuff through until they accumulate enough grime that some of the smaller particles may get trapped by the grime.  Until that buildup is sufficient to stop the small stuff, it passes right through.  It's the small stuff that bypasses the filters and sticks to the edges of your fan blades, or to the fins of your heat sinks.  I needed something better.
A Moment of Genius:
One spring morning I was performing the yearly maintenance on my walk-behind lawn mower and noticed how the air filter is smaller than a 140mm fan, and about as thick.  The light bulb went on.  Fast forward a year, and I completed my project for a compact-ish air filter that fits inside an ATX case.
The Compromise:
There is one problem with using a real filter on the intake of a computer: real filters are very difficult to pull air through.  To combat this airflow restriction, we must use two solutions:
  1. Increase the size of the filter surface
  2. Increase the static pressure of the fans
Every filter will restrict air flow to some degree.  Here are common filter types arranged according to airflow-restriction:
Open Window > Foam Filter > Fine Mesh Filter > Paper/Cloth Filter > HEPA Filter > ULPA Filter > Brick Wall
If you make the filter more restrictive and desire to keep the same rate of airflow, then you need to increase the surface area of the filter.  If you run out of room to make the filter taller or wider, then you can fold it (pleated).  That will make it thicker.  The filter in this picture has been folded, then curved to make it roughly the same shape as a coffee can.
If you've made it as wide, tall, and deep as will fit into your design and the airflow is still too low, then the next step is to get bigger/faster fans.  Sadly, standard computer fans don't have enough static pressure to pull a sufficient volume of air through a pleated paper/cloth filter.  We need to step outside of the standard computer fans and begin looking at commercial/industrial strength fans.
The best place I've found to shop for fans is Digi-Key.  Their web site allows you to search and sort according to fan properties.  I selected three fans: 70mm, 80mm, and 92mm; all of which are 38mm thick.  In Step 1 I have provided a link to a pre-filtered list of industrial-grade 12V fans at Digi-Key.  All of the results have a static pressure of at least 1/2 inch H2O (12.7 mmH2O), 12 V, 4-pin wires or connectors, and are 70 to 120mm.  Many of them with a tachometer output and/or PWM speed control input.
Why several different sized fans?  I know that different sized fans will have a different sound profile.  Each fan will have a different volume (SPL), base frequency (Hz), and harmonics.  I've never heard any of these styles in person, so I decided to experiment.  They might all be awful, or one of them might be perfect.  And yes, they all have the capability of being "OH MY GAWD THATS LOUD", but with a PWM speed signal coming from my motherboard, I know they won't run flat out all the time.
  • 1
    Purchase your fans
    Head out to DigiKey and find some fans you like.  Here is a query to get you started.
    • 12V
    • 4-pin
    • Tube axial
    • Static Pressure at or above 0.5 inches of H20
    • Sizes (square)
      • 70mm
      • 80mm
      • 92mm
      • 92.5mm
      • 119mm
      • 120mm
    NOTE:  The GitHub repository only includes OpenSCAD code and STL models for 70, 80, 92, and 120 mm fans.
    Update (2022-04-12):
    About a year has passed since I put this project online.  Everything has worked great.  There have been no issues with the build, and the inside of the case is still spotless, but I do still have some valuable information to pass along.
    1. Some time after I completed this project using the 70, 80, & 90mm fans that you see in Step 14, I went back and added a variant to hold 120mm fans.  Then I swapped out the 80 and 92 fans for two freshly printed 120s.  They look pretty sweet, but don't push a lot of air despite being nearly 12 Watts each, and their noise signature cannot be easily ignored at full speed.  Conclusion: Stick to the 80/92 sized fans.
    2. This is the 70mm fan used in the pictures.  At full speed it draws 2.60 Amps / 31 Watts and screams.  It's sound signature is that of a wailing banshee, but it pulls air through that filter like a champ.  I keep it spun down to 15% duty cycle by way of a custom fan speed profile on my motherboard.  It only spins up when something gets overheated, which is never.  I don't recommend this particular fan.  If I were to do this over again, I would move up to an 80 for the bottom unit.
    3. Each of your motherboard fan headers probably don't like powering fans that draw more then 1 Amp / 12 Watts.  When looking at the list of fans, keep that in mind.
    4. If you want to power one or more fans from a single motherboard header, and that load exceeds 12 Watts, you will probably need one of these.
  • 2
    Purchase your air filters
    Amazon or eBay, it's your choice.  Don't bother with the pre-filter.
  • 3
    Beg, borrow, or buy a soldering iron
    The soldering iron is used to heat the brass knurled inserts into the printed model.  My iron is a Hakko FX-888.  Total power is 70W, and works great for heating the #6 steel hex nuts when set to 730 F / 390 C.
View all 16 instructions
drcyberg wrote 04/13/2022 at 03:28 point
Your Project is Fantastic, but where are the HDDs!?
Turranx wrote 04/13/2022 at 04:32 point
Are you wanting me to mount HDDs to the output of the fan?  I had considered doing something like that for 2.5" SSDs, since they are small and light weight.  Tell you what, if you clone my GitHub project and build then post a 2.5" holder of your design, I will link it here.  But the posted files need include source code and images.
