Watercooling Fan Monitor
Fan speed controller for a watercooled computer.
0 followers
This is a simple device to monitor the coolant temperature of a water cooled computer and adjust the fan speed accordingly.
The idea is to maintain the minimum fan RPM to keep the computer from overheating so that noise is kept to a minimum
It's also intended to control the speed of a PWM enabled pump, and monitor the flow rate using a Koolance flow rate sensor.
Current design constraints:
The system will monitor and control:
  • 3 Fans
  • 1 Pump
  • 1 Flow rate sensor
  • 2 Temperature sensors (ambient and coolant)
This could be potentially expanded, but this is all my system requires.
Communication is intended to be over both USB and RS232
  • 1 × STM32F103C8T6 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × Koolance INS-FM14 Liquid flow rate sensor
  • Flow rate and serial console
    Matt Tyson03/21/2021 at 02:05 0 comments
    Liquid flow rate captured using a Koolance INS-FM14 flow rate sensor.
    Basic serial console that prints out system information implemented.
    Next:
    Code cleanup.
    Serial console input.
  • Basic control loop implemented
    Matt Tyson03/13/2021 at 08:34 0 comments
    PWM control of fans is implemented.
    Temperature monitoring is implemented
    Basic control loop of reading temperature and update fan speed from curve is implemented.
    Next tasks:
    Implement flow rate monitoring.
    Implement RS-232 serial interface.
View all 2 project logs
s wrote 03/07/2021 at 04:30 point
what kind of display is that? looks interesting
Matt Tyson wrote 03/07/2021 at 21:21 point
It's a 256x64 OLED SSD1322 display I bought of aliexpress. The U8G2 lcd library is driving it.
