gathering supplies
03/25/2021 at 15:14 • 0 commentsMy enclosure arrived and is definitely big enough for the application. I also bought a MP3/MIDI/WAV/OGG play + record module with an SD card slot from adafruit. Hopefully the only other thing I need is a microphone, an SD card, and a speaker or an audio jack so I can play the files back without removing the SD card. Oh wait, the module comes with an audio jack.
a possible enclosure is on the way
03/05/2021 at 16:01 • 0 commentsMy buddy at OKW Enclosures is sending me a waterproof version of their newest product, the slim case. https://www.okwenclosures.com/en/Plastic-enclosures/Slim-Case.htm
here's a more expensive thing I could hack
03/01/2021 at 20:05 • 0 commentshttps://www.amazon.com/WinBridge-Amplifier-Microphone-Loudspeaker-Waterproof/dp/B07BDJ4TRQ/
Bonus: I get to pretend I'm the Sham-wow guy in the shim-sham-shower. -
here's a thing I could hack
02/28/2021 at 23:14 • 0 commentsThis thing is waterproof and has a microphone for all those calls you take in the shower. Maybe I could hack it into a recorder.
https://www.amazon.com/SB510-Resistant-Bluetooth-Handsfree-Speakerphone/dp/B00IN2S072/
