13" laptop hard-shell case
1 High gain alfa wireless adapter
2 power supply banks (ups)
1 fixed/unfixed keyboard with onboard track pad
1 tethered phone
1 10" shell/screen for raspberry pi 4b+ (running Kali natively)
Evey single cord/wire on this setup are all tucked away completely.
Very compact. I used velcro strips to fix the keyboard to the shell/screen also the wireless card and one power bank are also velcro.
Cell phone has usb debugging enabled for an instant wired connection upon booting up the device and will never run low on battery since it's always plugged in. (burner phone)
The power banks both get around 2 hours each depending what's being done.
Nothing in this setup ever has to be removed.
The shell/screen for the pi is also strapped in place.
When it's time to zip the case closed not one single thing in this case moves or is sticking out. The screen has nothing pressing on it.
Flush when zipped if you will.
