SPP Adapter board - A240721-R270921.zip
All the documentation needed to build the SSP (Standard Parallel Port) Adapter board (A240721-R270921) including schematic, PCB assembling guide, Gerber files for PCB production. PCB is 55mm x 60mm 2-layers.
x-zip-compressed -
747.10 kB -
11/06/2021 at 10:10
Download
S310121-R231021_68k-MBC_IOS.X.production.hex
The IOS in executable format (.HEX). This executable file is intended for the use with MPLAB IPE (or any other equivalent SW) to program the PIC MCU directly.
x-hex -
87.37 kB -
11/05/2021 at 18:29
Download
S310121-R231021_68k-MBC_IOS.X.zip
The sources for the IOS (with the needed libraries). Unzip into a folder and open with MPLAB X IDE (I've used version v5.45. No warranty that it will work "out of the box" with newer version of MPLABX IDE!). IOS must be uploaded into the PIC18F47Q10 flash. See the CHANGELOG section on main.c source for more info on changes.
Zip Archive -
2.01 MB -
11/05/2021 at 18:30
Download
SD-S310121-R231021-v3.zip
The content of the microSD for IOS S310121-R231021. See the CHANGELOG.TXT file inside the SD root for more info on changes.
Zip Archive -
2.34 MB -
04/18/2023 at 17:22
Download
EF06120-A2-user manual.pdf
QR203 printer commands (it is referred to another model but the commands seem to be the same of this one).
Adobe Portable Document Format -
424.74 kB -
07/23/2021 at 17:57
Preview
ide68k30.zip
68000 IDE installation files. Unzip into a folder and run SETUP.EXE to install the 68000 IDE on your Windows system.
x-zip-compressed -
2.63 MB -
06/15/2021 at 16:37
Download
A020221 - AUX RS232 Cable.pdf
The schematic of the RS232 AUX cable.
101.99 kB -
04/14/2021 at 13:17
Preview
CPM-68k Manuals.zip
The complete collection of the 4 Manuals of CP/M-68K.
x-zip-compressed -
16.00 MB -
04/14/2021 at 09:37
Download
Arduino Uno PIC programmer v1.zip
PIC programmer using an Arduino Uno. All the needed SW/FW with my changes already applied, and all the documentation of the "ICSP Shield" board (A170421).
x-zip-compressed -
281.60 kB -
09/24/2021 at 10:33
Download
A091020-R140221-SCH.pdf
68k-MBC Schematic.
389.57 kB -
04/12/2021 at 11:09
Preview
A091020-R140221_v3.ods
68k-MBC BOM file.
spreadsheet -
15.13 kB -
04/12/2021 at 11:10
Download
A091020-R140221 Assembly Guide.zip
68k-MBC PCB Assembly Guide.
x-zip-compressed -
76.61 kB -
04/12/2021 at 11:12
Download
A091020-R140221_GBR.zip
68k-MBC Gerber files for the PCB production (100mm x 100mm 2-layers).
x-zip-compressed -
344.36 kB -
04/12/2021 at 11:11
Download
