Coil winding
A project log for Plant pod
Modular plant grow module
Nikola SecerovskiNikola Secerovski 06/12/2021 at 16:450 Comments
Latest attempt to simplify construction of the solenoid part of the eclectic valve/pump...
Here is some aluminum tape cut to width of about 20mm, used in place of magnetic wire. We will test this type of coil further, and post update with the results...
