On Hold
A project log for PewPew S2
Even better PewPew
dehipudeʃhipu 06/11/2021 at 21:150 Comments
Since my experiments show that using the parallel interface for the display doesn't make it fast enough to handle the bigger display, I don't see much point in continuing this project. The larger display with parallel interface was really the most important innovation compared to my other projects.
I might resurrect it later on, if I find a way to speed things up, or maybe use a different microcontroller again. For now, I'm putting it on the back burner.
