Digital Bird Motorized Dual Action Camera Slider
Part1 of the Digital Bird full Camera motion control system which includes Camera Slider, Pan Tilt Head and Video Turntable all WIFI linked
The DigitalBird Dual action Camera slider is the first component of a complete wireless motion control system offering a host of features. The complete system offers a compact dual action slider, Pan Tilt head, and Video Turntable all WIFI linked and controlled through a colour TFT display. The system know uses the amazing 32bit duel core ESP32. All parts of the system work with full Acceleration control. The project is completely open source with kits available to make this a one day build. The kits will save you a lot of time with the build taking about half a day. News Update • Coming very soon- 6 key Sequencer, Video Turntable, Focus motor kits are available here: https://digital-bird-motion-control.myshopify.com/
Features:
  • A choice of Two WIFI Controllers, Compact controller for  programmed moves only or the PTZplus for added Realtime functionality  controlling up to three camera systems.
  • Dual or single action slide
  • Hot swappable Sony NP style batteries
  •  Limit switch for automatic setup
  •  Vertical lifting capability up to 4KG with the Digital Bird Vertical support base
  • Super silent stepper drivers provide smooth quiet operation in micro stepping mode.
  • Magnetic encoder allows hand positioning of the camera.
  • Locking mechanism for ease of transportation.
  • Compact mono rail with no belts in open space to snag.
  • Flip out feet for speedy setup in single action slide mode
Operating modes:
  • A-B straight run
  • A-B with acceleration controls (ramp/Ease)
  • A-B-A Bounce mode
  • Time-lapse mode with built in intervalometer and camera shutter control
  • Six key sequencer for more complex moves.
  • Stop motion functions for animators.
  • PTZplus real-time camera functions.
You can watch the build video here which will take you through ever step of the slider build.
NextionDisplayTopESP32-1.1.stl
Standard Tesselated Geometry - 55.36 kB - 04/09/2021 at 11:18
Download
ESP32 NextionDisplayCaseBack.stl
Back cover for nextion control box print 25% Fill
Standard Tesselated Geometry - 36.70 kB - 04/05/2021 at 11:16
Download
ESP32 Display Hinged Plate.stl
Small hinge part for display Tilt print 100% fill
Standard Tesselated Geometry - 17.86 kB - 04/05/2021 at 11:16
Download
ESP32 Display plate Hing.stl
Display Tilt plate for new Remote display print 25% fill
Standard Tesselated Geometry - 8.68 kB - 04/05/2021 at 11:16
Download
10-CtrlBox.stl
Housing for Main board print 25% Fill
Standard Tesselated Geometry - 158.82 kB - 04/05/2021 at 11:12
Download
View all 28 files
  • 13 × M5 Black Low profile bolts 10mm Long
  • 6 × M5 Black Low profile bolts 20mm Long
  • 3 × M5 Black Low profile bolts 30mm Long
  • 3 × M5 Black Low profile bolts 50mm Long
  • 2 × M2.5 Cap head bolts 30mm long
View all 34 components
  • Nextion Display enclosure part update
    digitalbird0104/09/2021 at 11:26 0 comments
    Top box for Nextion display has been made 2mm deeper to allow more room for cables. I found when assembling the remote that it was difficult to get everything in without putting pressure on the back of the display which can stop the touch from working properly.
  • DigitalBird Motion Control Update
    digitalbird0103/31/2021 at 11:00 0 comments
    UPDATE   31st March 2021
    For any one following this a quick update on where I am with the complete system.
    The port over to the ESP32 is know complete and opens up a new world of possibilities due to having so much more processing power, and better WIFI . The ESP32 also has much better certification and will allow me to ship complete kits without troubling over the legalities!
    The new mother boards are on the way as I write this and anyone who purchased a kit with the old board will have it replaced free of charge.
    The Nextion display is know a remote which is WIFI linked to all parts of the system and movable between them or just held in your hand.
    There are some other small improvements to the slider including an improved method for tensioning the belt and the locking mechanism which is on the introduction video but not shown on the build video. The Nextion display as mentioned is to become a remote and therefore the hinged plate has been revised to accommodate this.
    The Pan Tilt head is ready for release and I will be doing this as soon as the new pcb boards arrive. Since making the original overview video the head has undergone a number of improvements.
    1) The head can know accept a 1:50 gearbox on the Tilt which should significantly improve its lifting capabilities on heavier systems. Previously I was using 1:30
    2)The Nextion display can know be mounted directly on the face of the head so no need for the additional buttons for IN, OUT and PLAY.  Know there are only two buttons on the control panel one to mount the head the other to dismount all other commands are through the nextion.
    3)There is know an RJ45 port on the face of the head ready to accept the up coming focus motor.
    4)Because the ESP32 is so powerful all three steppers Pan/Tilt and Focus and controlled by a single CPU
    5) The pan access is know powered by a Nema17. Previously I was using a nema 14 but with the demand to allow the system carry heavier gear this also had to be upgraded. Unfortunately this means the head is also slightly longer, something I was hoping to avoid but form follows function as they say.
    The Video Turntable also is having an upgrade. Just as capable but more compact and offering the added benefit of being usable on the slider as a simple Pan Head. This will be released shortly after the pan/Tilt head.
    The focus motor is well under way and  I am just awaiting parts before finalising its pcb design and testing. Probably another month or two away before this is ready for release largely due to parts shipping times.
    Additional software features Just started working on a method of allowing multiple key frames on the moves which would give us the ability to program say 6 key frames with user selectable speed and Acceleration ramps between each.
    That's it for know if you can thing of anything else you would like to see on the system I would love to here from you. I cant promise to satisfy every request but if it is at all feasible I will take a look.
  • How do some companies get away without certifying their devices?
    digitalbird0103/09/2021 at 12:55 0 comments
    You may be asking yourself how companies such as Sparkfun, a business based on selling electronics kits and wireless development kit companies continue to sell large numbers of non FCC authorized kits, with seeming impunity. For Sparkfun, the rules that apply in most cases relate to “subassemblies”. This just means that Sparkfun’s customers will most likely use the products to build larger products containing a number of subassemblies. For example, that may include an Arduino™ processor board along with several sensors or peripherals and an LCD. The user may even put all of these parts into an enclosure. If the user sells this product containing multiple subassembly parts in an enclosure, for all intents and purposes they are now a “manufacturer” and their equipment is subject to the normal FCC authorization procedures.
  • FCC and other regulatory restrictions around RF
    digitalbird0103/09/2021 at 12:52 0 comments
    For those out there like myself working on Kit projects be sure an d make yourself aware of the legal requirements before they hurt to much.
    I found this to be the clearest article on the subject
    https://emcfastpass.com/fcc-rules-kits-subassemblies/
  • FCC Regulations
    digitalbird0103/09/2021 at 12:48 0 comments
    Was blissfully unaware of the breadth of the FCC regulations concerning RF component imports!
    Unfortunately due to different import regulations around RF/WIFI component imports I am unable legally to supply the RF-Nano board or the Nextion display as part of the kits and so those items will have to be sourced by the maker separately. A real pain in the ........ On the plus side these are readily available everywhere .
View all 5 project logs
  • 1
    Digital Bird Duel action Slider Build Video
    Everything you need to know is given full instructions here. Keep up to date with any updated here also.
  • 2
    Important Note: Latest Updates to the System
    Please note I have know moved the whole system away from the RF-Nano over to the much more capable ESP32. There have also been a number of changes to the parts since making this video so please be sure to download the latest parts either here or from Thiniverse website before you start printing. The biggest change to the slider is that the Nextion display is know a WIFI remote which can be freely moved around the system to best suit your working preferences. I will be adding another video soon to show the changes.
View all instructions
